Question about O2 Xda Orbit Smartphone
Blank white screen xda orbit
Phone boots up ie blue screen then green screen then a white blank screen can not get into any function in the phone
  • 3 Answers
The only solution is to format your phone but you will loose all data.
Posted on Jan 16, 2009
Black screen on XDA Orbit
when the screen goes black, ''restarted'' - do you restart the phone or does the xda restart automaticly?
thinkin whether its a battery/power issue..
Nov 21, 2009 | O2 Xda Orbit Smartphone
Xda orbit, screen cracked but display ok yet touch function not working?
Digitizer glass is broken, LCD underneath is OK. Replacing the digitizer is tricky even if you get the right one. Often just as cheap to buy the complete replacement digitizer+LCD for around $20 shipped on eBay.
Sep 16, 2009 | O2 Xda Orbit Smartphone
O2 xda orbit Screen display problem
hi what u need to do is go on ebay get another screen then go to www.blueunplgged.com and type in the name of your phone like nokia 3410 screwdriver get this screw driver and i will tell you what to do cost of this in all 10pounds or i have the tools to sell you if you would like once you have done all of this E mail me glenroy1112@yahoo.com
Xda orbit 2 won't start up
sir plz its same problam with me thanks
svicky2001@yahoo.com
Aug 11, 2009 | O2 Xda Orbit Smartphone
Danny
try a hard reset
when turning on you're phone hold down the keys above ok and start and then use something to do a soft reset(it's a little hole in the left side of the phone)
you will see a welcome screen just press the buttun under yes(the green key)
i hope this works for you
Jun 16, 2009 | O2 Xda Orbit Smartphone
FROZEN GREEN SCREEN ON XDA ORBIT 2
The only way to solve your problem is that you will have to format your phone by pressing the reset batton along with both function keys in front untill somthing appears on the screen.
Jan 09, 2009 | O2 Xda Orbit Smartphone
I am having problm in hard reseting my o2 xda orbit phone...can you help me?
By a hard reset I presume you mean resetting to manufacturers default settings?
If you can boot your device, the easiest way is to go to Start > Settings > System Tab > Clear Storage.
If you cannot boot into Windows Mobile on your Orbit then the best way is to hold down both the left and the right soft-keys (the two keys with _ marked on them, either side of the wheel) at the same time whilst you poke a paperclip (or similar pointed item) into the reset button on the left side of the orbit. This will initiate a hard reset on the device.
Nov 27, 2008 | O2 Xda Orbit Smartphone
AFTER FLASHING MOBILE DEAD POWER IS`NT ON.
It sounds like you've had problems writing a custom ROM to your phone. You have done it correctly using the CID unlock. Are you using the same WM6 ROM that you have done before?
Firstly, turn off your XDA Orbit.
Then hold down the voice recorder button on the left side of the phone
Then press and hold the power button on the right side of the phone, whilst still holding the voice button on the left.
This should get you into "bootloader mode" which will display a screen with red, green, blue and white stripes - yu should now be able to instlal your ROM using the RRU from the computer with USB connection
If that is not possible, you can install the ROM from a microSD card if you first format the card into Fat32 file system from your computer, then copy the NBH file from your ROM to the microSD card. You will need to rename the NBH file from the ROM to ARTEIMG.NBH for this to work.
Enter bootloader mode and you should see a prompt to press the volume button downwards to start the ROM installation process.
See this page for more information on the MicroSD ROM installation:
http://wiki.xda-developers.com/index.php?pagename=Artemis_SD_Card_Flashing
Nov 09, 2008 | O2 Xda Orbit Smartphone
O2 xDA Atom Exec Screen Blank After SofReset
Couple of things you can try to fix the issue, firstly try a hard reset
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost
Try that and if it doesnt resolve the issue then we can try another solution
Aug 23, 2008 | O2 Xda Atom Exec Smartphone
O2 Xda Orbit Smartphone Logo
350 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
