Question about HP ProLiant ML350 G4 Server
Proliant ML350 g4 internal health led: red and green alternate
This morning the server is turned off. I turned on, but now the screen is black, internal health led alternates red and green. Any suggestions? Thanks in advance.
  • HP Master
  • 2,878 Answers
Open the case and turn it on. There should be corresponding red light indicator inside or possibly the back.
Posted on Dec 05, 2012
  • 4 more comments
  • Stefano Cutone Dec 05, 2012
    Hi Jose, it corresponds to pair black yellow
  • Jose Diaz
    Jose Diaz Dec 05, 2012
    ??? http://h18000.www1.hp.com/products/quick...
    It's led n.2
  • Jose Diaz
    You still need to identify internal LED on main board.http://support.wavesco.com/kb/20090504/p... Look for the other diagram.
    Ok, sorry I must have misunderstood. Then...1) Green, 2/3) Off, 4) Amber, 5) Off, 6) Amber, 7-14) Off. The server has only one processor
    P.S. There are two sticks of ram used, no. 13 and no. 14
3 Suggested Answers
  • 48 Answers
SOURCE: HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Posted on Mar 20, 2009
kamal1984
  • 1383 Answers
SOURCE: Second Led on HDD is flashing Red
you can run "chkdsk /r" coomand to recover your harddisk.
Also if you can delete partition and then create new partition thehn format it so all errors are fixed .
Posted on Jul 16, 2009
Server no display when power on
Can you confirm that server fan is rotating or not when server power on. and which led glowing red when you power on server
Mar 15, 2014 | HP Compaq ProLiant ML350 G3 Server
My hp ml370 g4 startup and the health led is green but when the dignostic utility appers on screen the health led become red and the keyboard not responding help plzzzzzzzzzzzzz
Open the case and turn on. There should be a corresponding led lit inside. That, or you could run Insight Manager. It will tell you exact details.
Feb 28, 2013 | HP ProLiant ML370 G4 Server
ML350 G3 S/board CPU Error Amber LeD + Internal Health Error
You will continue to get internal error until you add memory. It shouldn't even boot without RAM.
Feb 04, 2013 | HP ProLiant ML370 G4 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
Server crashed
need to have re installation of your Operating System
Jun 16, 2009 | HP ProLiant ML350 G4 Server
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
HP ProLiant ML350 G4 Server Logo
953 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
