Question about Toshiba 62HMX84 62" Rear Projection HDTV
Fan motor to light is humming
What can I do to fix it. I replaced the bulb about a year ago and it has worked fine since then but I turned it on this morning and that sound came on to.
  • Anonymous Apr 10, 2009
    fan motor for light bulb humming louder n louder each day
    Champion:
  • 240 Answers
This noise is most often not the fan at all but the color weel motor.
start pricing color weel replacment for your model
a good parts place is www dot parts store dot com
Posted on Jan 12, 2009
My Hunter fan with light kit has a problem, again. The remote control works for the fan but not for the lights. One bulb burned out. Then the remote stopped working. Replacing the burnt out bulb did not...
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Aug 04, 2011 | Hunter Ceiling Fan Remote Receiver...
Annoying hum on the projector
are you sure its not the fan?
I supose its good to clean the fan and the inside ones a year.
dust gets in there.
The fan could be failing.
il get back to you about the humm
Mar 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Where can i order a new motor for this model
Check this response from 2008 for same model fan.
By resorrowsr on Oct 26, 2008
Fan stopped Turning - Removed fan to check all the connections. All the connections were good. When you turn the fan on, you can hear a humming sound. If you take off the blades you can spin the motor and it will work, but will not turn on it's own.
    • resorrowsr
    • 2 years ago
    I called Home Depot customer service. I had my receipt, so they gave me store credit for the full purchase. Since I have two fans, they wanted to know if I wanted to replace both fans. I told them one was still working fine, so I only replaced one. My problem was the transformer. You could see where it had overheated and melted.
http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=Hampton+Bay+73554+Antigua+Ceiling+Fan&langId=-1&storeId=10051&catalogId=10053
Jan 30, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Nov 12, 2008 | Lutron #D-600PH-DK 600W SP Push Rotating...
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Emerson quiet cool
a real hummer. humm can be the sound of a short.but it sounds since u did only turn the fan on it hummed ...fanns are blower motors in acs the motor I bet ate it and needs a new one no way of fixing the motor but most are easy and cheap to replace...go or call an ac applance man ...see if he got a good used one for you or go the manufacture take model make serial no. sometimes u can spin the fan while on and it takes off again...this is dangerous so use a plastic long something but will dy again after u turn it off. good luck. CrazyLarry
Jun 30, 2007 | Emerson Quiet Kool 10MW42K Air Conditioner
Toshiba 62HMX84 62" Rear Projection HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
