Question about Nintendo The Legend of Zelda: Phantom Hourglass for DS
HELP WHERE IS ROMAOAS DADS SECOND HIDE AWAY!!?!?!?!? the clue oe whatever is : its under the spot where the lines drawn between my stone tables intersect
  • rdemidoff Jan 11, 2009
    thx ill try it. and what do u mean what chapter?!
    uhmmm i just followed the ghost ship and than the fog appeared and i keep getting sent bavck to the same spot so i had go to molida island and i went in his secret cave and found his first hide away and now i need to find the second hideaway
First you have to go to molida island and you have to have the shovel. the shovel is in his first hide away. to find his second hide away dig a hole right in front of all the palm trees. step on the hole and if you fall through it you will fall into his hideaway.
Posted on Jan 16, 2009
  • 8,197 Answers
Try here to get the help you need it is the walk through for the game. you need to know the chapteer you are on though.
http://guides.ign.com/guides/694756/page_3.html
Good Luck and Please Rate FixYa!
Posted on Jan 11, 2009
Tehre is little posts sticking out of the ground (example on banan island) between islands and theres a tresure chest on the other side but its to far to jump!!?! help!?!? how do i get the treasure chest??
Posted on Jan 14, 2009
  • rdemidoff386 Jan 14, 2009
    tehre is little posts sticking out of the ground (example on banana island) between islands and theres a tresure chest on the other side but its to far to jump!!?! help!?!? how do i get the treasure chest?? i can jump onto the peice of wood and stuff!
How to attach to my craftsmen router? I've inherited my Dads router, router table,and router guide. I have no idea how to use them. Will you please help me?
I have a craftsman router and table. On mine you remove all the screws from the base plate, set the base plate aside and use same screws to mount the router to the underside of the table.
May 08, 2017 | Saws
Need to convert stones to kilos please. can u post me a DIRECT link to one as I can only get links to links to more links! thanks.
Try this site: http://www.convertunits.com/from/stone/to/kilos . Fill in the blank in front of stone and then click Convert!. (This is the second blank line.) The answer will show up on the next line (labeled kilos).
1 kilo = 0.157473044418 stone
I hope this helps.
Jan 26, 2011 | Office Equipment & Supplies
New granite countertops big circle spots on.
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
Dec 28, 2009 | Jenn-Air JED8430 Electric Cooktop
I have a Dewalt dw 705 miter saw.when you pull the trigger the saw starts for a second and then shuts off. I have replaced the brushes and it worked for a few minutes and quits. the brushes do not seem to...
the armature needs to be cleaned or it is possibly bad (open bars) They make a special cleaning stick called a commutator stone that you might be able to purchase at a local repair shop. If you are not comfortable trying this I would recommend taking the saw with you, To clean properly you have to remove a cover and have the saw running, I would also check for proper movement in the brush tube allowing the brush to freely contact the armature. Let me know if you need more assistance and I will try and help.
Nov 10, 2009 | Dewalt Saws
Glass reinforced concrete composite stone table broken
Believe it or not Gorilla Glue holds that sort of thing quite well. You may have a visible line, but not too bad providing you keep the pieces held together tightly for an hour or so (it foams and expands -- scrape off the excess after it dries.) I would also get some epoxy (the thin stuff, not the putty stuff) and some fiberglass mesh and reinforce the bottom. Something else -- some contractors who do foundation repair have an epoxy and carbon fiber mesh that would do that and be indestructible -- see if you can find one in your area. I could give you someone in my area, but that probably wouldn't help you. You'll have to call around. If you can't find it, the fiberglass mesh is used in boat, RV, and tractor trailer repair so one of those shops should be able to sell you some.
Nov 02, 2009 | Welding Tools
6150 scans leave a line down the scanned image
There is probably a speck of dust on the scanning unit. You can unlatch the glass scanner table and, with the unit powered down and the cord unconnected, gently pull the scanning unit out (or you can start a scan and power down the unit when the scanning unit is in the middle of the table). Opening the scanner table will void your warranty!
Examine carefully the glass "window" of the scanner in the area corresponding to the dark line using an angled light and see if you can spot the dust. You can clean the window glass with a lint-free cloth dampened with alcohol. Do not press hard on the scanning unit since the mechanism is quite delicate. Afterwards, carefully replace and latch back the glass table.
If the dark line does not go away, you might have a faulty scanner, but that's unlikely.
Oct 27, 2009 | Lexmark X6150 All-In-One InkJet Printer
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
Headset Problem Rosetta Stone
3.Open Sound
Dec 27, 2008 | Rosetta Stone Chinese Mandarin Level I &...
Stain on marble/stone table
use a simple paint remover
what kind of paint was used on the pumpkin?
Oct 21, 2008 | Sport & Outdoor - Others
Nintendo The Legend of Zelda: Phantom Hourglass for DS Logo
356 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
