Question about Dolphin Maytronics Advantage
How do I reverse the float/handle on a Dolphin Deluxe 4?
Does the handle position have anything to do with the robot working
When the cleaner reaches the water surface the direction it travels to scrub waterline is dictated by the direction of the handle. The handle should be at a diagnal to the cleaner. You should reverse the direction of the diagnal frequently to prevent the cord from tangling and kinking. Cord should also not be coiled up tightly during storage.
Jul 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Maytronics dolphin deluxe 4
Probably From the company that made it. Try searching by part number. It should be on the PCB somewhere.
Aug 13, 2013 | Computers & Internet
My dolphin pool cleaner is floating
try machine washing the filter bag, sometimes air can get trapped inside the filter bag due to micro debris clogging it up. If necessary remove a float off of the handle as well
Nov 24, 2011 | Dolphin Maytronics Advantage
The cord keeps tangling. How can I keep this from tangling? I've tried stretching it, etc. but nothing works
The float/handle has a reversable position. You must periodically flip, change it so as to avoid this problem. I would reverse it each time I used it.
Jul 21, 2011 | Dolphin Maytronics Advantage
Cleaner wont reverse.will try to climbe out of pool wont reverse. this is a dolphin superkleen.
Contact Maytronics, manufacturer of the Dolphin cleaners, for troubleshooting assistance and referrals to regional service centers directly at www.maytronicsus.com or 1-888-DOLPHIN.
John
May 23, 2011 | Dolphin Maytronics Diagnostic Robot...
Dolphin starts to climb walls and then tips over.
There are several things that could cause this problem with these automatic pool cleaners. Try the solutions below.
1. Your pool cleaner might be too heavy. To correct, empty and wash the filter bag and add floats if necessary.
2. There may be too much algae growth on the walls that is preventing traction. Brush the walls prior to vacuuming if you have excessive algae growth.
3. The water temperature could be too low. Make sure pool water temp is at least 65 degrees.
4. Make sure there is not water inside the handle.
5. Make sure the brushes are not worn. You might have to have them replaced if they are worn.
6. Pool cleaner might be too light. Remove handle floats and attach 8 oz. weight to bottom inlet cover if necessary.
7. Debris could be caught in impeller.
Jul 24, 2010 | Smart Pool Inc Dolphin Diagnostic...
How do I replace the two drive belts on a dolphin sprite? I have the belts.
Thank you for posting your question here on Fixya.com.
Remove the handle screws and pull off the handle, then remove all twelve screws inside the case (6 per side) to remove the side plates. Once these are out of the way, remove the old tracks and install the new ones. Reassemble in reverse and you are done.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 19, 2010 | Dolphin Maytronics Diagnostic Robot...
My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
Jun 14, 2010 | Dolphin Maytronics Advantage
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
My dolphin pro robot does not sink
Assuming you have tried to turn it upside down under water to get all the air out there are only a few other things you could try...
1) Remove the handle floats that are clipped onto the handle itself.
2) Inspect the bag. Is it 'greyed out' and dingy looking? As it accumulates debris inside the fabric it becomes harder and harder for water to pass through and eventually it can become so clogged that air cannot evacuate thru it. If that is the case, replace the filter bag.
For a quote on a replacement bag, contact us at www.arrowpools.net.
Oct 28, 2009 | Dolphin Maytronics Advantage
Dolphin Maytronics  Advantage Logo
124 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
