Question about Hardware & Accessories
How to program 110123-130 24 hour timer
We have an Armstrong 24 hour timer for our water heater Model # 110123-130, and cant figure out how to program it. So if you have any any solutions or know to to program it. Pleaase let us know
  • 5,245 Answers
1) Copy following link to how to set FM1 series 24-hour timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
2) With your timer, move override button to center position.
Each pin located around edge of dial represents 15 minutes.
Move pin outward for ON, and inward for OFF.
Set current time by rotating dial until current time appears on clock face.
http://waterheatertimer.org/pdf/Armstrong-FM1-timer.pdf
3) Include photo in your question so expert can see timer and make possible identification
Posted on Dec 03, 2012
3 Suggested Answers
agent91
  • 2100 Answers
SOURCE: new woods timer ..i cannot figure out the correct
I will try and explain it to you, but bear with me, if it isn't exactly what I say, it is close. You have 220 volts coming into the timer from the fuse box, you should have 3 or 4 wires, one on them being bare, the ground, and one being white, neutral, the other 2 should be black and red, both hot, or both 110 volts each. Connect the bare wire to the green ground screw, the white wire should be connected to the Neutral , (silver) screw on the line side, It has to connect to the timer to run the clock. The other 2 will be connected to the line side, Now the wire to the water heater is the same make up, 3 or 4 wire, 2 hot, one neutral, one ground, Put the hot wires, black and red on the load side of the switch. 2 screws. The white wire connects to the silver screw on the load side, or it should anyway. and the ground of course connects to the ground screw. The hot wires should be on brass colored screws, but not always, as in the case of the word "load" written there, they might not be brass. Usually are. The timer needs the neutral to run, so don't just wire nut the white wires together to get it running because it won't . There should be 4 wires, all modern electric stuff is 4 wires now days. 220 volts. There might be a little white already in the box going to neutral for the clock, check it out. This should work.
Posted on Aug 28, 2010
SOURCE: I want to reset the
1) Open following link to read about re-circulation systems:
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Image below show typical FM1 analog timer dial with pins:
Move pins with fingernail or small tool.
To test if pins need to be moved in or out, set pins each direction and manually rotate dial clockwise and listen when pump turns on-off.
How timer operates: clock motor rotates dial continually, pins on dial move lever that turns circuit on-off.
To set current time, manually rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Some timers have a selector switch: move switch to Auto, or Timer, or Timer ON. Again you can manually rotate dial and check which setting is correct.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 14, 2011
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
I got a package with 2 timers. I had no problem setting the first, but on the second, I want to use a 12-hour clock. Seems it came programmed for a 24-hour clock, and I can't figure out how to change...
Westek TE22 two-pack offers choice between 12 hour am-pm display or 24-hour 'military time' display.
Open following link for typical manual
http://waterheatertimer.org/pdf/TE22DHB-manual.pdf
Look at step 7 in manual under Clock Time Setting.
Step 7 says, "press - button for 3 seconds to choose display"
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Aug 30, 2011 | Hardware & Accessories
I have a Amrstrong Astro 25B050S recirculating pump on my 50 gallon State water heater (both installed in 2006). The timer works fine and the I can hear the Astro pump and the pump feels very hot to the...
If the pump is very hot, unplug it.
Heat damages motor coil and indicates that pump is not rotating at correct speed, or not rotating.
Take apart and clean inside pipe with white vinegar or CLR to see if pump rotor can be freed to rotate.
If pump does not rotate after cleaning, then replace pump.
Aug 16, 2011 | Astro Systems Armstrong Astro 20B050S-TA...
I have a Paragon model 4004-20 Water Heater Timer and I moved the TIME arrow. Now the water heater is not working at all. I am thinking of just restoring full time power to the water heater. I did not...
You are not supposed to move the time arrow.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
4000 series time arrow is pointed at 8:00.
To set current time, lift and rotate dial clockwise until current time lines up with pointer.
Put X2772 trippers on dial at times you want water heater to turn on.
Minimum on-off with Paragon 4000 is 1-1/2 hours because trippers are so fat.
You can replace 4000 timer with electronic timer and control exact on-off down to the minute:
http://waterheatertimer.org/Boxtype.html
Electric water heater heats about 21 gallons of water per hour.
Shower uses 6-9 gallons hot water.
Bath uses 10-12 gallons hot water.
Average water heater that is not connected to timer, runs about 3 hours a day. You can make timer pay off by keeping time schedule lower than 3 hours.
Following link shows how to figure cost for electric water heater:
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Following link shows several ways to save with water heater, plus general information to save money long-term:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 21, 2010 | Heating & Cooling
I cant figure out how to set it.
http://waterheatertimer.org/pdf/Woods-59203.pdf
The manual has step by step instructions.
Plug timer into wall to recharge battery.
If battery will not charge, the timer is no good.
Press reset to clear memory.
Select am/pm format by holding clock button.
Set current time by holding clock button down while pressing hour, and then minute and then day
To program timer:
Press program button once and program1 ON displays
Press minute button to set program1ON minutes
Press hour to set program1ON hour
Press days to choose the day or group of days for program1 ON
Press program button again and program1 OFF displays
Press minute to set program1OFF minutes
Press hour to set program1 OFF hour
Press days to choose same days for OFF that you chose for ON
Press program button and program2 ON displays
etc.
To exit programming, press clock
A conflict in programming will cause timer not to work as expected
Make a schedule before programming to avoid program conflicts
maximum load 1000 watts
Nov 08, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
I need an instruction manual for Brinks model 44-1030
Did you ever get a manual for the timer? I have one too and cant figure out how to program it. I also cant find the instructions.
Nov 22, 2009 | Hardware & Accessories
We have a westpoint wkw1225tl and the program
once machine fills with water a pressure switch activates to say stop filling now wash/ the motor should then start and heaters operate with the timer decreasing dont know your model too well but hope this helps you....
Nov 05, 2009 | Washing Machines
Hardware & Accessories Logo
193 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
