Question about Samsung HTZ-510 Theater System
Protect message when i turn my dvd player on i get the protect message and the dvd player switches off
  • Samsung Master
  • 19,396 Answers
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 3 Answers
It may also be over heating. Especially if it's in a tight space or stacked with other electronics. Try relocating it to a cooler spot.
Posted on Apr 21, 2010
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: The DVD player will stop playing and the message
It is possible that your system is gettting overloaded and makes the sfety cicuit switch off . This is the protecction circuit to prevent further damage and fire within the system particularity when the output or power is shorted. Check from the speakers for short remove and test . Also use a multimeter to test for short in the output drive. If so disconnect and see if the protect releases. Then you must replace the outputs. Check also the protect cicuit for a false alarrm due to wrong biasing. Hope this advice helps to figure out. Good day
Posted on Jul 21, 2010
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
I have a Sony dvd player DAV-DZ870W when turned on it displsys the word PROTECTOR push power what is the cause of this?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
Apr 23, 2014 | Audio Players & Recorders
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
SHOWS "PROTECTED" THEN SWITCHES OFF.
hi m8 did u find out how 2 do the " PROTECTED " ???my dvd player do th same
Jan 11, 2011 | Samsung HT-TZ215R Theater System
Jul 20, 2010 | Sony DAV-C450 System
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Guru
I was moving around my large woofer speaker last night and then all of a sudden the unit went into protection mode. I tried all the various solutions posted on here and nothing worked. Then I went back to my speaker connections on the woofer and unplugged them and plugged them in again and it seems to be ok now. Very annoying problem. Can I suggest unplugging all the speaker cables and replugging them back in. Also another solution may have been holding down the power button when powering up the unit. Give all the above a try.
May 22, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
DVD turns off with "Protection" message.
it may be becoz you are using too many things from 1 plug socket / power adapter.
Aug 14, 2007 | Samsung HT-DS1000 System
Samsung HTZ-510 Theater System Logo
193 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
