Hi, I have a HP Photomsart 2710 All In One and when I scan pictures and bring them up in Kodak to edit them, they all come out with these yellow lines through them. I already checked the glass and it's clean. It seems to be inside of the scanner where it's coming from. Do I have to take it in to be cleaned or, am I able to disassemble myself and see what the problem may be? I appreciate your help and feedback. Thanks.
Tools Needed:
Small star shaped screwdriver
Flat Head screwdriver
Patience (not the kind a Dr has-the kind we learn from delayed gratification)
Clean Soft Cloth
I have an HP 2710 All In One and here is what I did. First I wasted 2 hours with online and phone support. They do not know how to do this so don't bother them with it.
1.) When you lift the cover lid you will see 2 clips holding it onto the printer base. Gently lift he cover near one clip at a time or both if you are really carefull not to break them. They come out easily no force needed.
1A.) Remove the star shaped screw from the top left corner of the glass. You can buy a tool kit online that is gray and has about 20 pieces for working on electronics which cost from $10 to $20 that will have the star shaped screwdriver you will need (its the smallest one in the set.)
2.) Now look at the keypad you will see a black plastic cover with some of the following words on it: On Setup Scan at the top of the little cover and HP Photosmart 2710 all-in-one printer fax scanner copier near the bottom of the cover. Now being very cautious this panel can be pried up by using a fingernail or really thin (really thin small flat head screw driver or fingernail file- you get the point) to pry this up. It is easy so don't force it.
3.) Once the little black cover is removed, LOCATE the big long Black and Color Start buttons near the bottom of the buttons panel. You will now see a square just below these two buttons with two slits beside it.
5.) Using a screwdriver that will fit inside the square hole, push the screwdriver down into the square and it will release a latch or you may have to hold it down. Gently pushing from the back edge of this panel slide it forward about one inch (the area above the Display *DO NOT PRESS ON THE DISPLAY PANEL - GO BEHIND IT ABOUT 2 INCHES AND PUSH FORWARD ON THE SILVER PLASTIC COVER AREA) This should allow the panel to slide forward a little bit and then it can be lifted.
6.) Gently slide off the 3 connecting cables (DO NOT TOUCH THE SILVER CONNECTORS ON THE END AND DO NOT BEND THE CABLES.) The one with the red and black cable needs to be removed gently so as not to damage the connection to which it attaches on the boards. Lay the panel with the buttons facing downward so as not to dirty or destroy the motherboards and connectors on a clean surface.
7.) Now look for the two star shaped screws and remove them.
8.) Now RAISE The top lid as if you were going to install a new ink cartridge. You will need a flat screwdriver for this step. Look at the front panel where it says Wireless and the blue light normally is. Below that on the bottom side of that panel you will see a rectangular slot where you will need to pry the cover out just a little ways then you will want to slide it up towards the ceiling. It is actually slid into a slot on the dark black panel. It may help to have 2 people do this since one may need to hold the screwdriver to keep it pried up while the other slides.
Once the Silver cover that says Wireless on it is removed you will now see a couple of Star shaped screws that also need to be removed. ALL SCREWS ARE THE SAME SIZE SO DON'T WORRY ABOUT MIXING THEM UP.
Posted on Dec 02, 2009
  • loghomes Dec 02, 2009
    9.) At the back of the scanner glass near the area where you removed the lid you will see two 1 inch long clips you can gently pull up on the clips and then you can remove the panel which has the glass attached. Clean the glass using the Alcohol and a clean soft cloth or EYE GLASS CLEANER works well. You can't clean it enough. I cleaned it 5 times before reinstalling it. Check it in the light for streaks etc and make sure it is clean enough to last you a while before tackling this again.
    Reinstalling all parts simply follow these steps backwards then plug back into the power supply and happy scanning, printing, faxing and copying. DISCLAIMER> Not responsible for human mistakes or errors. This is exactly what I did tonight to fix mine and it worked great. Have about 1 hour of free time to do this. GOOD LUCK
HP 2710 with win 7, will not access the HP Solution Center for scan. This is a local printer.
Is HP Solution Center installed? Start > All Programs > HP Solution Center If it is there, you may need to configure the 'scan to' feature before the scan will show up on computer.
How to do this is specific to the HP model printer/scanner. Here's is a link on HP support's website to the user's guide.
Nov 15, 2010 | HP Photosmart 2710 All-In-One InkJet...
I have downloaded the latestHP 2710 AIO installation software and installed it as recommended. I am unable to get the printer to perform scans. Reports Error1706. Despite trying two of the recommended...
Hi ddegas
I believe your installation was incomplete. You need the driver as well as the software which is required for scanning.
Try once again
Choose your Op System and download then install the driver and the software.
Hope this time, it will work for you.
Good luck
Nov 23, 2009 | HP Photosmart 2710 All-In-One InkJet...
I can scan and edit the text with the Kodak ESP-3
You can edit the pictures using Kodak's retouching software.Scan quality was a little better but also retained the dark compression issues.
The Kodak ESP 3 comes with great software for editing photos and applying touch-ups to portraits, but printer software is only as good as the physical results, and the print quality isn't nearly up to current industry standards. Your $150 would be much better spent on alternative multifunction printers.
Oct 01, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Photosmart 2710 ALL-IN-ONE is connected to my computer, which runs on Windows X (not VISTA). Printer and copier always work, but I could never get the scan to work and now I need it. It says "No scan...
Go to the HP website and search for the driver, re-install it, its HP Director software and you can then scan with it. I have the same printer and had to do the same thing. the download took about half an hour on a broadband connection. You will then need to scan to a file, the images of the scan come up in the software and you manage them from there. i will tell you that the software is not user friendly. good luck.
Dec 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
I have a Photosmarat 2710, and my computer runs software Version X (not Vista). I can copy and print but not scan. When I try to scan it says I need to install or run HP software. The only software I got...
If in case the software is completly installed then try the steps mentioned bellow.
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
432 people viewed this question
