Question about Exercise & Fitness
Repair dc motor controls on Treadmill Lifestyler mod, 831,296462
Can control speed under no load; treadmill stops when under load
    Top Expert:
  • 12,223 Answers
No. this happen because had been lack of maintenance LUBE. Lube the deck belt, you must do it every week of use normally. Use 100% silicones or wax instr. manual.
2) LUBE the rollerer bearings too.
3) Test the input voltage motor, if there are Voltage the motor need repari.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Repair dc motor controls on Treadmill Lifestyler m - 12_3_2012_6_07_31_pm.gif
Posted on Dec 03, 2012
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
  • 6 Answers
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
Posted on May 26, 2009
Reapz
  • 6 Answers
SOURCE: treadmill will not start
Better know someone who can fix it, like who you got the Treadmill from. Maybe they can help you, it's better if you had the warranty. Or you can trade yours in for another one. That always helps.
Posted on Jun 01, 2009
SOURCE: Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Posted on Jun 03, 2009
  • 13 Answers
SOURCE: Treadmill won't slow down
if you look at the front roller. there will be a black device that has two wires. this is your speed sensor. Make sure it is facing the magnet on the roller.
Posted on Aug 10, 2009
Replaced motor and motherboard board through warranty but belt still won't work. Not even the power noise will turn on.
The motor, or a connector to the motor, or the controller is faulty. If you can measure DC voltage at the motor (up to 90VDC), but the motor won't turn, and if you can manually move the treadmill belt with your hand or rotate the motor pulley (POWER OFF) with your hand, then the motor's dead. Even IF it was replaced under warranty.
If you can't measure any DC voltage to the motor under any conditions, then the problem is in the controller or a connector. Try measuring directly at the controller board.
Jul 26, 2014 | Weslo Cadence G 5.9 Treadmill
Machine shuts off- says LS
follow this steps and fix it. God bless you
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
Sep 19, 2013 | Bowflex Exercise & Fitness
Lifestyler Treadmill Manual
Contact manufacturer, they will usually send you a free copy.
May 21, 2013 | Treadmill Doctor Lifestyler Expanse 2000...
My lifestyler expanse 850 control panel has stopped working but the belt still works?
1( adjust the REED switch, see the diagram, clean it, and tight the wires connectors very well.
2) replace the batteries.
3) clean the contacts batteries with special cleaner
4) retight the spring contacts batteries for better contacts.
5) tight the ribbon cables from keypadys vs display board.
6) tight the display board connectors vs lower board.
Jul 10, 2012 | Treadmill Doctor Lifestyler Expanse 850...
Can I replace the motor and control board on a Lifestyler 6.0 treadmill with ones from a Lifestyler 8.0
Dear Sir:
You must contact to the factory, the reason is the they differente design for the electronic, like RAM, ROM, EPROM, etc. Maybe CAN NOT BE compatible.
But the last word , has the factory. you can reach them, and ask for the consulting, very important.
sincerely.God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 11, 2012 | Exercise & Fitness
I want a speed controler for a PM dc motor . the spec for the motor are. 180 v 7.5 amp 4800 rpm Duty Treadmill Part no 7.22 316400 model46300-17 .Magnetek NPL 877-7. I am making a machine and I...
Hi, Can you use the treadmill speed controller ? Or you could by a AC/DC invertor drive , http://www.inverterdrive.com/group/DC-Thyristor-Drives/SSD-507-Eurotherm-Shackleton-Rapier-Drives-503-504/default.aspx
Thats a link for a possible option for you , you often see them in exchange and mart or Craigs List .
hope this helps, please rate accordingly .
Aug 31, 2010 | Heating & Cooling
Healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Jun 28, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
I have a LifeStyler Expanse 1500 treadmill. It appears to start normally, but when you get on it, it starts to speed up. For example, when the speed is set to 2.9 and you get on, it will speed up to 4.2...
You may have a belt and deck problem. Test by the following procedure:
without the power on stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction I first apply silicone lubricant and see if that clear up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem.
Jun 12, 2010 | RTO Exercise & Fitness
I have a Lifestyler 8.0 Treadmill. It keeps
Use a good silicone Spray under the belt for every 10 hours of use
Jan 02, 2010 | RTO Lifestyler 8.0 MPH Treadmill Walking...
Treadmill powers up begins to turn belt then shuts down
Did the shop only do a continuity check or a real load test with amp check also? Motors can look good and run with no load but fail under load.
Mar 25, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
99 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
