Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Cobra 29 i want to take out the maxima power out of my cobra 29 ltd
It's all about R55 and L14 and etc.
Posted on Jan 12, 2009
5 Suggested Answers
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
  • 773 Answers
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
  • 11 Answers
SOURCE: low transmit audio cobra 29 ltd nw
Hey Tim, Hook your radio up to a fairly nice modulation meter, and check the output on the meter. If it's below 100%, then adjust VR-4 until you get 100% output. Do not use anything metal to adjust it with. As metal drivers and ect. will give you a false reading, and if you slide off the varible by accident, it could blow your radio.
Get It Done!! J.R.
Posted on Jan 08, 2010
  • 146 Answers
SOURCE: how to match a antenna to a cobra 29 LTD Classic
You are actually tuning the antenna to the vehicle it is mounted on here are some very good resources.
Be aware that if your radio has been modified it may produce a dirt signal that an swr meter may read as reflected power. In this case it may be more accurate set with a unmodified radio also if your radio is setup for a linear it may have a deadkey to low for the swr meter to calibrate correctly.
Hope this was of help.
Posted on Nov 28, 2011
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
Were is the tuning pod on a cobra 29 ltd for more power output ?
how much power do you want? 4 watts is the max other than that those people that were splashing you will now be splashed by you.
Mar 13, 2012 | Cobra 29 LTD CB Radio
How to fix the dimmer light ona cobra 29 nw ltd classic
Feb 04, 2011 | Cobra 29 LTD CB Radio
Unknown if transmits, does not recieve
Feb 01, 2011 | Cobra 29 LTD CB Radio
Cobra 29 ltd (1993)
Looking at the schematic TR23 colector ties in with
the power switch ,check D22 it's a 9.1 to 10 volt
zener diode also check C11 an D21.
TR23 shows to be a 2SC1096 I would go ahead and
replace it.Be sure that the CB-PA switch is in good
working order;
Good luck maybe this helped.
Sep 03, 2009 | Cobra 29 LTD CB Radio
I have cobra 29 ltd has power going into radio but wont com on when you turn power knob
remove the outer casing, there is a glass fuse..( 1.5 amp ) has probably blown
Jul 30, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Jul 28, 2009 | Cobra 29 LTD CB Radio
How to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
Apr 25, 2009 | Cobra 29 LTD CB Radio
Cobra 29 issues
Check D23 and D28. They are polarity protection diodes. It could also be the power knob.
Nov 09, 2008 | Cobra 29 LTD CB Radio
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
161 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
