Question about Home Security
Morse alarm keypad, flashing "Morse" green light. Nothing in the handbook
Alarm system otherwise appears to be working.
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
TLRogue
  • 99 Answers
SOURCE: 98 a6 alarm system keeps going off in middle of
There will be water in the door microswitches, for the central locking.
This caused the alarms to activate when locked.
remove door panels on both front doors, you will see a little electrical switch near the door lock. remove and check for water ingress.
TL
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: Alarm light flashes; lcd toner low. But it's not!
I found this in an online forum:
"Chip on the cartridge MUST be replaced with new one."
Sounds like the MF5700 series operating system won't recognize a refilled cartridge that does not contain a new microchip.
Anyone know if this is true - and if so, any workarounds?
Posted on Jul 04, 2009
cene765
  • 787 Answers
SOURCE: Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
Posted on Nov 05, 2009
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
Ids 816 alarm system problems
My indicator lights are not working on my control panel eg, power light etc, yet all the numbered keys are lit up. When I take the plug out the wall then the whole control panel does not work, need help please, I am not currently able to arm the alarm.
Apr 25, 2013 | Home Security
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
Sep 22, 2010 | Honeywell 5804 Ademco Wireless Security...
Alarm not beeping when doors are open. led on door goes red when door is opened and alarm box has red and green lights when alarm is actived but not chimes or alarm when doors are opened
When a zone has both red and green lights on, it means that it is in delay mode. That means when the sensor is triggered, the system will wait for a predefined time interval (30 seconds) for user to reset the trigger. During this time interval, the system will not beep or alarm. But after that, if user does not reset the trigger, system will go off.
User can reset the trigger from keypad or by remote.
Sep 05, 2010 | Skylink Group Skylink Security System Kit
The alarm is going off and the keypad wont work
If you are having this problem the first thing to do is disconnect the battery, then connected back and see if the alarm is working again. If is not working replace battery on your alarm keypad, otherwise you will need to replace the whole alarm system. Good luck.
Dec 30, 2009 | 1991 Chrysler New Yorker
All alarms go off; 1 of 6 alarms has a flashing green light
Your alarms are interconnected, meaning when one alarm goes off, they all go off. The alarm with the flashing green light is the one that triggered the alarm. If it only went off once, it was probably just fluke thing, and you can reset the alarm memory (flashing green light) by pressing the test button. If it happened more than once, you should try cleaning the alarm. Do this by removing the alarm, and blowing compressed air into the sensor opening (located around the back side perimeter of the alarm). If this fails, replace it.
Aug 09, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
