Question about Briggs & Stratton Briggs And Stratton 15kw Home Standby Generator
Generator won't start after it's been used for a power outage
Tech does the annual maintenance; generator works on the first power outage; generator won't work on the next power outage; tech does another annual maintenance and generator works on the first power outage but then doesn't work on the next power outage.....
  • Pam Wayman Dec 05, 2012
    this generator hasn't worked properly since we bought it right after Katrina
Circuit board
The ASCO 165 does not switch the home onto the generator during testing / exercise. Unless you manually press the test buttona nd hold. If the power goes and the generator starts, look at the two LED's on front and make sure the generator LED is lit, if it is then the transfer switch is accepting the generator power quality and should switch, if it does not, with everything off generator etc, kill the main breaker feeding the ATS, if the generator starts and it still does not switch you have a board, or position of siwtch micro switch, or rectifier problem in the ASCO. Let me know if you need a manual or you kind find easily on the net, ascopower.com
May 23, 2013 | RTO ASCO 165 Series 200A Automatic...
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
Frigidaire gallery dryer won't start
It is code that every major appliance is to be on it's own circuit (breaker). I would have an appliance tech check the electric in the dryer for shorts. It's possible the terminal block got shorted. The best thing to do is buy a voltage tester, put it on the block and see if it beeps. If it does, the dryer is getting power and it's an internal problem. If not, then the problem lies between the breaker box and the dryer.
May 21, 2012 | Dryers
Need to know if I can run my fridge on small generator if there is power outage. Generator is 1600/1650 Watts; Amana fridge model TC18HG nameplate says 6.5 Amps. But I'm unsure about the starting...
Hello Bob,
There should be absoluty no problem on that 1600 watt generator..at max when compressor just starts its drawing about 750 watts, that is the max usage when running its about 500 and on defrost its like 850 ..so on 1600 watt generator no problem
Aug 25, 2011 | Amana Refrigerators
Coleman 6200 won't work
Hi Judy,
Generators DO last a good long time for the money, but they have to be both used and maintained in order to keep working properly. What has most likely happened is that you didn't use the generator at all for a year, after it sat on your dealers shelf for a few months not being used, and so the tiny bit of magnetism it uses to "kickstart" the process of making electricity has worn down. The good news is that this is easy for a generator shop to repair, no parts involved and the minimum labor that they charge. They need to do something called flashing the field of the generator. What they can't do is get Coleman to pay for it since they aren't around anymore, go ahead try the 800 number (waits patiently).
Be nice to the poor generator techs at the shop.
Nov 24, 2008 | Coleman Powermate Premium Plus 6250W...
Briggs & Stratton Briggs And Stratton 15kw Home Standby Generator Logo
23 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
