Question about Music
AJANTA wall clock : Musical & Pendulum M.No.-427 wall clock connections.
I have one ajanta Musical & Pendulum M.No.-427 wall clock and recently it stops its musical function coz all wire connection related to music section goes disconnected. and i cant figureout which connection to connect where and i dont have a same wall clock available to see the connections.
  • 1138 Answers
SOURCE: musical instrument, Holton & Co. Cornet serial # 192673
You might find help here:http://en.allexperts.com/q/Antique-Musical-Instruments-2370/Holton-Cornet.htm According to this site:http://www.horn-u-copia.net/cgi-bin/yabb231/YaBB.pl your cornet was made between 1948 to 1949. Where it was manufactured will have some bearing on its worth but the bottom line is always the condition especially of the valves and tuining slides. Hope this helps.
Posted on Sep 01, 2009
  • 5603 Answers
SOURCE: yamaha musical keyboard makes mono tone when turned on?
Check that you have the exact power adapter for the unit.
Posted on Dec 03, 2009
  • 1138 Answers
SOURCE: I think I am quite confused for what I want.
You sound like you have a good grasp of what you would like to do. There are lots of videos on Youtube of people using some of the gear you mentioned. Also check each manufacturers site for forums on the gear you would like to use. The forums usually consist of members who are all friendly and have good advice and solutions for any problems you may have. Remember that even the most experienced musicians started somewhere and are all still learning and are very willing to share what they know. You might consider using a laptop with an external hard drive. I think the Akai gear is very good and has good support and expandibility. Decide first what main pieces of equipment you would like and contact as many dealers as possible to get the best price. You may be pleasantly surprised and have enough of your budget left over for something you hadn't thought of yet. Good luck and enjoy your playing. Remember to study all your manuals carefully.
Posted on Jan 21, 2010
adracamas
  • 344 Answers
SOURCE: i want to send the 15 pieces of musical
In a sturdy box lined with some good foam for shock absorbing, i would surely use several layers of varying density. http://www.closedcellfoams.com/ has some really good materials for packaging things like this. Contact them for estimates and such.
Posted on Mar 25, 2011
  • 10 Answers
SOURCE: Amplifier not working
It is more likely that your input jack component is broken or damage you would have to take it apart because your circuit board may need a look at to check for damage and you will need a new input jack
Posted on Aug 11, 2011
Hi, when using the gain control on my amp I get a buzz and an 'osilating' sound. I've tried several guitars and leads but still the same problem, any suggestions?
Hi.
If the amp is working, then most of the time the buzz is given by a bad grounding. Test the amp using different wall sockets, and possibly test it in a different home (there may be an earthing problem with the home network). If the problem goes away, then it was the wall socket or the home power network. If the buzzing is still there the problem is with the amp. Check the earth connection at power cord and psu and test the amplifier's PSU components. Check also the audio connections inside the amp (the back of the female jack input sockets). A small contact in there will result in a loud buzz.
Aug 09, 2011 | Fender G-DEC Junior Modeling Guitar...
I bought a behringer bxl3000t yesterday and when I plug it to the wall it gives me a pretty big noise, even when the bass is not plugged in, If I turn the amp on without anything plugged and all the knobs...
Since you just bought this, exercise your warranty (assuming you bought this new). The amp probably will have a slight buzz with nothing connected... the question is how loud it is. If you can hear it loud at five feet, that is too much. If you bought this used, prepare to have it serviced at a shop.
Jun 29, 2011 | Behringer Ultrabass Bxl3000
I'm attempting to connect my new axiom pro 61 via Midi cables to my mbox2. To do this I understand I must rely on the power supply rather than USB. When plugging the axiom in to the wall it will not turn...
The AXIOM SHOULD turn on with just the wall wart adapter so you HAVE A PROBLEM.
First thing is to check the adapter that it is the correct one. It should be a 12 VDC 1 amp unit with positive center pin output.
Common adapters for pedals WILL NOT WORK.
Assuming you have the correct adapter, VERIFY the connector is plugged fully in the AXIOM.
Feb 09, 2011 | M-Audio Axiom Pro 61 USB Keyboard + Sp2...
Amp was working,now it will not turn on and no lights
Every amp like this has a fuse on the board inside the amp. Remember to be VERY CAREFUL poking around in these! Please!!! These carry a charge enough to KILL YOU! EVEN UNPLUGGED.
I would disconnect it from the wall, disconnect the two wires on the speaker remembering exactly where they were. - + .. Take the amp's head out removing the four scrrews on top. To reveal the circuit board. Look for leaking capacitors first. They will look like soda cans. They might be laying down or up right . The biggest ones pay attention to and look for ***** substance leaking out. The upright ones will have a flat top/ Bad ones will be buldge on top. and leaking. If everything listed above looks ok? Find the glass fuse and remove it to get the correct voltage and amps for that fuse. and replace it . Never run an amp without the speaker connected.
Jan 31, 2011 | Peavey Vypyr 30 30watt 1x12 Modeling...
I have an SWR workingpro 2x10c combo solid state amp. When running a signal into the standard input with all pots set at 12 o clock, the signal sounds very distorted. I have tried a basic troubleshoot,...
You haven't told us what "signal" you ran in... Make sure ALL interconnected equipment is powered from the same receptacle. All audio lines should use balanced interconnects where possible using XLR or TRS cables. Cross connect another amps preamp into the effect loop input to check the power amp portion.
Dec 15, 2010 | SWR WorkingPro 15 Amp Combo Bass
I plugged the USB to MIDI lead input nd output the wrong way around on my Alesis Sr 16 and it stopped working. Have I blown something inside?
You should NOT be able to damage the unit by reversing in and out on MIDI connections.
MIDI connections are fairly safe against damage unless you drive a ground loop into the output ones.
ALWAYS operate any connected equipment from the SAME power source receptacle.
Fopr instance, do NOT have a musical device powered froma wall receptacle across the room and connected to a computer on the other side as an example.
Apr 07, 2010 | Alesis Sr 16 Stereo Drum Machine
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Does it have the option to load other sounds in it?
Here is the manual if you don't have it:http://www2.yamaha.co.jp/manual/pdf/emi/english/ssdrums/dtxp4_en_om_d0.pdf The set comes with 427 drum/percussion voices and 22 keyboard voices. If you use a midi cable plugged into the midi out on the sound module you can control other midi sound modules and midi devices by plugging into the midi in on them. Page 30 of the manual describes some of the parameters. If this helps please let me know.
Nov 19, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Fuse location line 6 spyder amp
you need to plug in cord and plug that into wall
Mar 23, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
280 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
