Question about Dynex Televison & Video
Why does my 42 inch rca volume go from 0 too 100 by its self
    Top Expert:
  • Dynex Master
  • 14,553 Answers
Bad volume up micro switch under the vol up button.
Posted on Dec 03, 2012
4 Suggested Answers
dave1645
  • 834 Answers
SOURCE: volume on Insignia 42 inch flat screen went out suddenly
you need the mainboard replaced
Posted on Sep 18, 2009
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
rickbrashear
  • 176 Answers
SOURCE: 42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
Posted on Jan 28, 2011
I have a RCA 42 inch that lost its picture but the volume still works in it. Would it be worth getting fixed
No.
(Unless you are capable of repairing it yourself)
These days, electronics are cheaper to replace.
Dec 04, 2016 | RCA Televison & Video
How do I reset the password on 42 inch panasonic t.v. ?
It can be reset by turning the tv on and while pressing the "volume down button on the main unit, press the menu button on the remote control for more than 3 seconds. The self-check menu appears on the screen. Then, disconnect the ac cord from the wall outlet. You will back to when you first bought the set.
Regards,
Joe Van Buren
Jul 20, 2014 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
RCA 7 inch table says no command
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
I have a 42 inch lg tv the volume just started going up to 100 or you can turn it back to 0 by it self why?
Volume controls are these days operated by an IC. If these go faulty all control is lost. It's not a job that can be done yourself as these IC are mostly flat surface mounted types with lots of pins to unsolder.
Apr 22, 2013 | LG LFD7150 Shelf System
Sound board on RCA 42 inch TV doesn't work
Do you know if there is voltage?The voltage came from the power suply line.Are you in the mute by accident?
Nov 02, 2012 | Televison & Video
May 21, 2010 | RCA L42WD22 42 in. LCD Television
I have a 42 inch sharp aquos and the volume doesnt work on the tv or satellite remote, what is the problem
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
My 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Aug 19, 2009 | Philips Televison & Video
Televison & Video Logo
19 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
