Question about Refrigerators
Kitchenaid manual for ksrs251 refrigerator
Ice maker not working
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghdh
Posted on Sep 30, 2010
watugot
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
jumptrout51
  • 3361 Answers
SOURCE: Ice maker not getting water. Everything else seems
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Posted on Nov 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: KitchenAid refrigerator ice maker is
It is either going to be the water valve or the ice maker itself. Nothing else except freezer performance itself is involved. The ice maker mold thermostat reaches 28 degrees and the ice mold heater and motor are activated by it. As soon as the ice moves a bit, the heater is shut down and the ice fingers carry on over to drop them into the bucket; shorly before the end of the cycle the ice maker fills itself back up, she comes to a screachin halt and waits once more for the ice mold thermostat to fire up another harvest. So what goes wrong? Faulty water valve. bad ice mold thermostat, poor freezer performance. Replace the water valve first. if that don't fix it then replace the ice maker. Then you will be back in the ice making business.
KitchenAid Service Manual
Posted on Aug 30, 2011
Ksrs251 ice maker will not stop making ice and it is overflowing. Sensor seems to be out and off switch not working.
Although your model number supplied is incomplete, you have an optic sensor in your unit, so either your sensor has failed or has be rewired. Your optics are located on the side wall of the freezer section and use a laser to detect ice volume. Does it produce when you turn this off? If so, replace the optics Part Number 4389102, this part does come with both boards for both sides. Check it first by turning it off and see if production has stopped, if it is shorted it will cause continuous production of ice.
Good Luck
Sep 29, 2013 | KitchenAid KSCS25FKSS Side by Side...
Our kitchenaid side by side refrigerator ice maker stopped working
heatman101
Oct 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker not getting water. Everything else seems to work fine. I can put water manually into the ice maker and get ice. But no water from the line. It is a KSRS251 superbra side by side Kitchenaid model.
Nov 09, 2009 | KitchenAid KSRS25IL Side by Side...
heatman101
ghdh
Jan 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
612 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
