Question about Brother MFCJ615W AllInOne InkJet Printer
Brother mfc-j615w offline
Its displaying offline
Teckies
  • 226 Answers
SOURCE: Brother MFC 8500 Fax machine error "offline"
ok. right click on my computer,
click on manage,
click usb ports,
delete all files named composite device.
unplug the cable from your printer
restart your computer.
plug it again the cable.
start your printer.
good luck...
Posted on Jan 23, 2008
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: i cant print any documents
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Posted on Nov 25, 2010
Selling my MFC-J615W and need to know how to clear the memory?
http://printersquestions.com/How-to-clear-Brother-MFC-J615W-memory.html
Apr 29, 2015 | Office Equipment & Supplies
Brother MFC-J615W says offline
Go into control panel, open up printers and devices, select printers, find your printer and double click. When the printer comes up you will be able to choose that printer to be online.
Feb 07, 2015 | Brother Office Equipment & Supplies
Thick black line when faxing and coping brothers ink jet model MFC-J615W
It really depends on how thick the black line is. If its say 1/2" to 1" thick then a segment of the contact image sensor has failed. If its very thin then that would be just dirt either of the scanner glasses or under them. When you open the scanner cover you will find two glasses. the thinner one is for the adf and the very large is for flat bed scanning. If you get the line when using both then the CIS is faulty and needs replacing. If either one is good with no line then it could be just the ribbon cable that goes from the main board to the CIS.
Aug 06, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
Mar 14, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
I want to hook up a printer/fax machine to my Wireless computer. HOW
check whether the wifi function of printer is on or not, there is utility of brother which searches the printer on pc after installation of the software , check it
Feb 01, 2013 | Brother Usb Cable/cord 4 Mfc-8840d...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
I need a copy of the manual of my MFC-J615W colour inkjet Multi-Function Centre
Brother MFC-J615W Manuals
Please visit the above support link for MFC-J615Wand download the required manuals which are in Adobe Acrobat (pdf) format.
Good Luck!
CreativeTECH
Mar 07, 2011 | Brother Office Equipment & Supplies
Brother MFCJ615W AllInOne InkJet Printer Logo
140 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
