Question about Kenmore Refrigerators
Kenmore elite series fridge water dispenser will turn on by itself flooding floor
Had to shut supply down to fridge as the dispenser would randomly turn on and water floods floor. i have already replaced all circuit boards in front area of fridge. A serviceman which killed me to call replaced the motherboard in back of fridge that my 9 yr old could have done. its a shame, good looking fridge ,but it sucks .i am trying to find the water valve which is not in the lower back as i have checked. is it inside behind the filter somewhere?Thanks
the dr
  • 447 Answers
SOURCE: I can't get water from my water dispenser
the water tank is probably frozen or the filter is totally blocked does the ice maker work? i take it its a french door bottom freezer? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
  • 6 Answers
SOURCE: Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Posted on Aug 07, 2008
  • 55 Answers
SOURCE: Frigidaire FRS26ZSH no water at dispenser or ice maker
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Posted on Aug 31, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
I have a kenmore elite refrigerator 795.79783.901 if I turn on water to fridge the water will not stop coming out of dispenser till I shut off the appliance waterm valve
you have a faulty valve on the dispenser.. possibly just a faulty micro switch keeping the valve open.
Neither are expensive.. but getting into the part of the freezer to change them, might be a bit tricky, as manufacturers always have hidden screws, to deter the uninformed, or to cause them to break more, and then call in the professionals. (them)
Apr 22, 2017 | Kenmore Refrigerators
Kenmore elite refrigerator water stopped dispensing from door
HI.CHECK WATER SUPPLY FIRST.then defrost fridge.if this basic fails u need to check 1-supply to valve 2-the valve itself 3-pipes 4 -microswitch.good luck ali
Jul 04, 2012 | Kenmore Side by Side Refrigerator
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
WATER NOT WORKING
Yes there is a shut off valve located usually under the sink or where ever it is getting its water supply, there is also the angle stops that you shut off that keeps water from going into the lines. check both of those, if there is still a issue, then it is something to do with the fridge. Something has got knocked loose and will need to be fixed
Jun 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water pouring from waterdispenser in side by side refrig
Dispenser leaking----Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser
Jul 01, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite HE3 Washer fabric dispenser not working
This is usually just as simple as adjusting the syphone up and down. releveling your machine or cleaning the dispenser itself. when the water enters the dispenser gravity syphones the water out . nothing really machanical about it. unless the water is not filling up the cup enough to go above the max line. you can test it by putting water in the dispenser above the max line and adjusting the syphone cap up and down.this should grab a suction.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
