Question about Dryers
My dryer runs for about 20 mins and shuts down Model # 11070056991
Dryer runs for about 20 min and shuts down after a buzzing noise and what sounds like a solonoid clicking on and off. I replaced the blower wheel and cleaned the dryer and lint chute out. I think it is overheating. It will turn itself back on after about 5 mins or so but will only run for about 5mins and shut down again.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
The motor is overheating and will need to be replaced. Here is the motor to order.
Posted on Dec 03, 2012
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
SOURCE: dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Posted on Nov 11, 2008
jtbjtb
  • 135 Answers
SOURCE: Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Posted on Jan 05, 2009
  • 659 Answers
SOURCE: loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Posted on Apr 10, 2009
erpaalai
  • 999 Answers
SOURCE: Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
Posted on Jun 08, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer runs for about 20 min. then shuts off will start after it cools down and run again for another 20 min.
The only thing that can be is a bad motor. Both the run and start windings are going at the same time. Start windings are not dropping out.
Sep 19, 2011 | Kenmore 66832 Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
I have a kenmore 90 series dryer model 110.60922990. It makes a funny noise while running for a few min. After about 10-15 min it shuts off and will not restart immediately, I have to wait for a few min...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 06, 2011 | Kenmore Dryers
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Loud buzz when starting, then shutting down after 10 min.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer runs foe a while 10 min. the it shuts off.
sounds as if you hav a bad motor assy, its tripping off on an overheat thermo and resetting when cools off, replace the motr assy
Nov 13, 2008 | Speed Queen AES28AWF Electric Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
