Turntable doesn't turn
  • lsedwards54
    lsedwards54 Dec 05, 2012
    I guess I need to give you more information ... when I lift the arm, the turntable does not move. No matter what we do, it doesn't turn. When I rub my finger across the needle, I can hear that through the speakers. My brother checked the belt & it's attached. He took it apart, but couldn't figure out what it might be. Thought it might just be the motor.
  • Audio Player... Master
  • 5,047 Answers
Most turntable motors are under 12 volts. What you can do to test it is remove it and attach a 9volt (PP9) battery to it. If that doesn't turn it then the motor has gone. If it does, either the power isn't getting to the motor or there's a faulty switch somewhere.
This solution is no good for direct drive turntables, but most of them don't use belts.
Posted on Dec 09, 2012
  • lsedwards54
    lsedwards54 Dec 11, 2012
    Thanks ... I will have my brother give that a try. I appreciate your help!
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Dec 19, 2011 | Audio Players & Recorders
Technics sl-BD20D turntable, attached pre amp but now have a loud hum, noticed there is a round jack with a pin in it next to the 2 outputs. Is this for grounding? Are there special cables that fit that...
Hi, Yes your turntable needs to be grounded to get rid of hum. Make sure that your turntable, preamp and amp are all powered from the same point. Most preamps do not have a grounding connection on them and when they do it is normally on the same side that the rcas from your turntable connect too. What is the make and model of your preamp. I will check it out. To earth to a preamp without a grounding connection do this. Take the grounding cable from your TT and slip it in the side of one of the 2 rca connections as you plug them in. That will ground your TT to the amp. If it doesn't then swap the ground lead to the other rca. Cheers John. Styluscity.com.
Oct 05, 2011 | Technics SL-1200MK2 Turntable
Turntable volume is low compared with other components. Could this be an analog to digital signal problem?
Hi, this is happening i suspect because the turntable is going into an amp that doesn't have dedicated phono input. Ie Cd or Aux. You need to get a preamp to boost the signal up. Cheers john. styluscity.com
Sep 04, 2011 | Technics SL-BD22 Turntable
Turntable doesn't turn, no heat. Turntable cleaned, installed properly
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 28, 2011 | Dacor Microwave Ovens
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 27, 2011 | Panasonic Technics SL-1210MK2 Turntable
My turntable does not have good sound? Is it the stylus needle?
It could be, first check all connections as they can come loose. It could also be the cartridge, the only way to find out is to get a new one. If you get a cartridge and stylus, you can fit the new stylus to your old one, if that solves the problem, you have a spare cartridge in stock, if it doesn't then replace the cartridge. If that doesn't work and the connections are good, then there is a fault on the magnetic cartridge pre-amp in your amp.
Jul 14, 2011 | Sony PS-LX300USB Turntable
HELLO,RECENTLY BOUGHT A ROTEL 1500 TURNTABLE BUT WHEN PLUGGED IN TO MY AMP I NEED TO TURN VOLUME TO FULL TO GET ANY SOUND.Only thing i can think of is that the wiring is fualty is it easy enough to rewire?...
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unidentified amp doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
Jul 14, 2011 | Audio Players & Recorders
I dont have the orginal ground wire for my Technics SL-BD20D turntable someone told me i could use rca cables to ground it, i have a pre amp cause my main amp didnt have phono jacks on the back of it.
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 22, 2011 | Technics SL-BD20D Turntable
    118 people viewed this question
     Grubhead
    Grubhead
