Pico 301 turn on but can not be locked on any source it just keep running the auto source finder on and on endlessly
The projector turns on but it cant be locked to any source as soon as you touch one of the command buttons it start looping in the automated source finder without stopping on any source, not the VGA, USB or any other source, it already was fixed once by Optoma a few months ago they changed the module, I used it once or twice for an hour or so and this happened
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If the set has a source button on the set itself try to defeat it (unsolder) to see if it is causing this--more common than most people think.
Posted on Dec 03, 2012
  • 87 Answers
SOURCE: Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Posted on Dec 23, 2007
bestdarngood
  • 3037 Answers
SOURCE: Optoma HD81-LV ... white lines on projected image
this has happened to many of these tvs, I would return it if you can, this isn't worth it to get fixed. I'm sorry if you can't return it, yours lasted less than many I have heard of
Posted on Mar 25, 2008
  • 4 Answers
SOURCE: My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Posted on Aug 20, 2008
rob52078
  • 40 Answers
SOURCE: Toshiba dlp 42in. keeps shutting off . replaced lamp 5 months ago
it sounds like your lamp could be failing. check your lamp it should be clear with no frost.. here is your lamp part number 72620067
Posted on Mar 15, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a KF42WE610 Sony TV, lamp was changed 8
Lamp Fan. or Ballast Board. for part number and prices call Encompass Parts 1-800-638-3328
Posted on Feb 17, 2010
On my projector it shows connecting pc only
Please check the cable ,this problem looks with your RGB cable
Mar 26, 2016 | Optoma Dlp Pk301 Pk 301 Pico Pocket...
Projector turns on, displays Brookstone logo and then turns off. It's not the power; the unit is plugged in.
It is most likely your lamp. If you replace the lamp then you need to reset the lamp timer back to zero or it will keep shutting off on you.
Jan 15, 2016 | Brookstone AAXA 50 Lumen HDMI 720p P3 Pico...
How do i turn off auto focus?
To strictly turn off the auto-focus, you have 2 options:
1. Some generations of 5600's have an Autofocus On/Off Switch. If so equipped, move the switch to "Off".
2. Remove the bottom cover. Locate the auto-focus motor and clip on of the wires that power the motor.
If repair is what you want to do, the problem becomes more complex and expensive! You will have to contact: www.micro-tools.com
You can order the 2 special tools, instructions and any other parts you need from them. When Kodak stopped supporting the slide projector business, micro tools bought out the remaining repair parts.
Feb 24, 2015 | Kodak Carousel 5600 Slide Projector
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to
Ensure a video source is connected to the projector (VGA, DVD, etc)
Unplug the projector to make sure it has completely shut down (not just went into sleep mode)
Plug in power and power on the projector (make sure video source is on first)
The projector should turn on and switch to the video source (manually select if not)
Once you can see the video source, push menu and turn off auto-off.
Auto-off should only work when the projector detect a video source is no longer present on the selected input. So if you are turning on the projector with no video source connected, it will usually turn off shortly after being turned on.
Nov 30, 2014 | Optoma HD80 Projector
The projector finds my VGA port and projects for a second or two, and then loses it, displaying the word "lost"
First check it with new best quality VGA cable. If the problem is still there, change the source connected to VGA port (i.e. Laptop or PC). Sometimes such things occur in Auto Source. Remove Auto Source from the menu for automatic selection of source. Keep the VGA port as first source to display. You will have to check it in the menu. In spite of Auto Source you can always select your desired source with source button also. If problem is still not corrected tell us the Make & model of the projector so that it can be better diagnosed.
Aug 06, 2011 | Office Equipment & Supplies
I amgetting an "out of
It is beacuse the video source resolution for the the projector is too high for it to display, you need to lower your VIDEO SOURCE resolution to the native resolution of the projector.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 11, 2010 | Televison & Video
My cinego is stuck on search mode. From the moment it turns on it starts searching as if I was holding the searching button down . The modes all run but search will not stop.
Try unchecking the "auto source select" box. Push the setup button on your remote (bottom row, second from the right), use the arrows (7, 0 , 9, or 5) to move across to "management" and down to "auto source select." Make sure it is unchecked (by higlighting it and pressing Enter, which is the 8 key).
Jul 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Projector keeps turn itself off
I have a Dell MP2300 with a bad power supply. Everything else is in excellent working condition. the bulb is less than a year old and has less than 500 hours on it. My asking prices are:
1. WITHOUT BULB: $50 shipping
2. WITH BULB: $150 plus shipping .
If you are interested, please contact me. I will also consider offers.
JJ
Bethesda MD - 301-588-7222
Jan 09, 2009 | Dell 2300MP Multimedia Projector
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
