Question about Vestax CDX-05 Turntable
Vestax cdx 05 sanyo
My turntables are coming up with err03 constantly and was wondering if my particular turntables were the Sanyo readers or the sony as may need replacement
4 Suggested Answers
quakemodo
SOURCE: Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
Posted on Dec 20, 2007
SOURCE: vestax cdx-05s
The problem is with the tiny grey switch that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Posted on Jun 18, 2010
  • 396 Answers
SOURCE: my turntable keeps skiping for no reason, no
What is the weight on the stylus? Flip the protective shield down to protect the stylus if available. Tare the tone arm (adjust the counterweight on the back of the arm until the arm floats perfectly level), then hold the counterweight and turn the dial markings to read zero. If you cannot find the recommended mass for the stylus you can use the average weight of 3g. Verify your tone arm is still floating in the center and the arm is perfectly level. Turn the counterweight until the dial indicates the specified weight of the cartridge manufacture specification sheet or you can set it for 3g if you do not have the specification sheet.
Posted on Jul 23, 2010
Vestax CDX-05 stutters and clicks when ejecting cd. Not all the arms on the transport assembly move when trying to eject a cd.
well to be honoust, it would be the best, but not price wise. I can't help you, only let a pro look at it with you by your side. It turnds and grabs the side and yesterdat i reard that loose components can be installed......
Dec 18, 2012 | Vestax CDX-05 Turntable
The jog wheel has snapped of the deck. was wondering if it is replaceable and where to get parts from. cheers
This is a major site for Vestax parts and accessories. If a part is not listed you can contact them and they will have it, it just may not be "listed." http://www.thomann.de/gb/vestax.html
Mar 16, 2011 | Vestax CDX-05 Turntable
My CDX05 kept skipping last night, it happened on 7 different CDs. The CDX was tilted up though, would this cause the problem?
If it was kept in a dusty place yes!
I would thus try cleaning the lens with a good CD lens cleaner product, that should get rid of any dust problem.
Apr 07, 2010 | Vestax CDX-05 Turntable
Vestax cdx-12 , left hand cddrive doesn't recognise discs imediately , sonetime not at all
In that case, the lens is weak. You need to change the lens entirely.
I wish you the best of luck.
Nov 05, 2009 | Vestax Cdx05 Table Top CD Player CD Player
Laser
The laser is probably dirty... Lasers last forever, or 100,000 hours of play, whichever comes first.
Use a CD laser Cleaner ... Radio Shack ($14)
It is a Audio CD with small imbedded brushes. No chemicals involved.
read the instructions carefully and turn on the volume when cleaning. The CD is an AUDIO CD and it will also give audio instructions.
Hope this helps! ... Don't take the unit apart...
Sep 08, 2009 | Vestax CDX-05 Turntable
Vestax PMC 05 PRO MIXER master output is not working
More than likely the output PCB might be faulty, or the signal amp might be damaged. In either case, not an easy fix. As for service in the UK, try HARD TO FIND RECORDS - they have a pretty good service dept.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 25, 2008 | Vestax CDX-05 Turntable
Disc Jumping
I used to have the same problem: the rubber feet of the players are too stiff. It is indeed vibration that causes the problem. Btw: after a couple hours in a club, you are usually playing much louder than at home, with more low-end punch.
I haven't had a single problem AFTER systematically setting the players on foam. This is similar to the tennis balls trick for regular turntables, except that here you need something a softer suspension as the players are very light. Shipping foam is good; camping foam mattress works also.
Jul 14, 2008 | Vestax CDX-05 Turntable
Pitch control center now 3.2% off center
maybe you should try a firmware update .follow the links on the vestax website about product support .
Dec 08, 2007 | Vestax Cdx05 Table Top CD Player CD Player
Hello, Mr. Dixon.
Peter Petrov
Dec 08, 2007 | Vestax CDX-05 Turntable
Vestax CDX-05 Turntable Logo
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
