Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Bar fridge My sylvaina bar fridge is not cooling..The compressor clicks on for about 30 seconds and the it clicks off...After 5miutes the compressor gets warm to hot...Does this mean the unit is gone? Is it worth fixing?
  • Jack Ing Jan 19, 2009
    Thanks Mr Mark 52 and Skeeter140..The little black box you refer to as the relay two pin connector, according to the schematic it is called the starter is that right? I shake it it does'nt rattle...After 30 seconds there is a clicking sound, according to the schematic it is called the motor protector with one pin connector...Both get warm to hot...Is there a motor inside the compressor? Someone said that the compressor will not work if the freon is low...The fridge is practically new, a shame to throw it away...2004 Sylvania se80102-3.....shade-ing
  • Jack Ing Jan 20, 2009
    Thanks Guys, I appreciate all your help...I will try to find a place to order this relay and hope that this will fix the problem.....To my understanding, when the switch does work the motor in the compressor will run? Looking forward in keeping the water bottles and most importantly the Beers cold!!!!!! I'll keep in touch of the outcome....shade-ing
  • 306 Answers
There is a PTC relay on the compressor you need to replace it. Small black square looking device take the wire retainer clip off and pry off the relay. Get the wires going to relay noted and then get the model number and make of your unit. Go to a parts house for appliances and get a new one. About 25 bucks for that little dude but it is a needed for your compressor. Could get a 3 in 1 relay they are a lot cheaper and easy to install. let me know how it goes ken
Posted on Jan 12, 2009
    President:
  • 1,214 Answers
Chances are, the compressor has locked up. You can try skeeter140's suggestion, but I doubt it will do any good.
Pull the relay off the compressor and shake it. If it rattles, then it's probably good. If it doesn't, go buy a new one as suggested.
Repair is not usually recommended.
Posted on Jan 15, 2009
  • Mark Egan Jan 19, 2009
    1) Yes, there is a motor inside the compressor.
    2) Yes, the relay inside the little black box is called a start relay, and it's either solid state (PTC) device, or it's mechanical. If it's solid state, just get another one as it's not easily tested. If it was mechanical, you should be able to see a heavy coil of copper or aluminum wire wrapped the outside of it. The rattle is a plunger/switch which makes up part of an electromagnet created by the coil.
    If the relay doesn't rattle, then the plunger is welded in the closed position, and that will cause the compressor to run about 30 seconds, then trip out on internal overload. When the overload cools, the compressor tries again, and the sequence starts all over again.
    And, so far, you've described nothing but an electrical problem. Don't go fishing into the freon side of the system because your looking down the wrong road if you go there. Unit's like this don't usually have low suction pressure switches on them (which would cause actions as you describe.). But, this unit's sounds too new for that to be the problem.
  • Mark Egan Jan 20, 2009
    Yes, the motor in the compressor will run.
    There are two windings in the motor, inside of the compressor. A start winding, and a run winding. Both windings are energized when the thermostat says "Make it cold in here.". But the start winding should only stay powered, through the start relay, for just a second or two, until the motor begins to run. Then the start relay drops the start winding out of the circuit.
    If the start relay does not drop the start winding out, the motor windings heat up, causing the internal high temperature reset to trip out (possibly after 30 seconds that you indicated.). Once it cools, the whole process starts over again.
Bar fridge not cooling
Sounds like you might be low on refrigerant (gas). Unless it is 134a, which you can buy in automotive stores, you are going to need a license to buy refrigerant. The simple way to see if you might need gas is by feeling the larger line going into the compressor (probably insulated). It should be cold if your system is working and charged. If you feel the line leaving your condenser, it should be fairly warm. Be careful as the line leaving the compressor can be very hot and burn you and you may have exposed electrical. If the lines do not feel cold and warm as they should you may be low on gas or you may just have a problem with your compressor or another part of the system. If you're not getting the warm-cold differential, it's likely worth just buying a new unit.
Nov 12, 2013 | Amana ARB1905C Bottom Freezer Refrigerator
Last night, we had an electrical issue... water got into an outside socket which knocked out the ground faulted outlet inside, which took out the fridge too. Once we identified what had happened we reset...
The compressor is high siding....i.e there was a BRIEF power outtage and it was repowered before the coolant system stabilized to the compressor does not stand a chance of starting due to high pressures so about every 4 minutes or so you should hear a click or note a brief blink for about 40 seconds of lights in the home. This is the termal overload cycling. The compressor / coolant system needs to equalize. Unplug it for 30 minutes then plug it back in and listen for the compressor to start. After a 10 minutes... feel the front of the chassis where the doors close. It should be warm to the touch. If you feel the chassis is warm... after 10 minutes everything should be back to normal. IF not respond with a complete model number. My bet is it will start after a 30 min rest.
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Microwave Ovens
Compressor running for about 30 seconds then off again the fridge and freezer not cooling
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Refrigerators
Model # msd2756de freezer and fridge stopped cooling, Christmas Day!!!!!!! unloaded freezer, fridge overnight the temp the next morning is 15 in freezer and 50 in fridge. moved thermostat back and...
heatman101
Dec 26, 2010 | Maytag Refrigerators
Loud click,compressor starts, immediately stops. Then a click ,fridge light dims for a couple of seconds. compressor starts and continues to run. Fridge cooling ok.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 30, 2010 | Frigidaire FRT17G4B Top Freezer...
The outside of the top freezer of my refrigerator has been getting very, very warm. It remains warm for maybe 30 min., then cools off, and then gets very warm (almost hot) again about an hour later, only...
That is usually caused by the evaporator fan not running. It's located under the fridge accessed from the back behind the cardboard cover. The fan should run when the compressor runs.
Jul 26, 2010 | Frigidaire Refrigerators
First gathered water at the bottom, thought that is was due to something touching the back. Stopped fridge, cleaned it, started it again. Light on but no familiar noice of the engine starting again. Engine...
Don't know the model/brand off the top of my head...
But: If the compressor is warm/hot, but nothing is happening, I ask this:
Even if the fridge is not cooling, is the compressor running, or dead silent?
If silent, but warm, do you hear a "Click" every so often ? Maybe 3 to 5 minutes apart, followed shortly by a 2nd click ?
If so, most likely the compressor has seized, and this is the over-current trip acting (thermal, so it needs time to cool).
Big problem if it is the compressor (expensive).
The only other thing that might cause a similar occurrence, would be if the compressor has a Start capacitor. If this has died, the compressor will not turn - just sit there getting warmer, as the over-current trip acts.
If it was a dead thermostat, the compressor wouldn't get power, and would be cold.
Dec 12, 2009 | Smeg Refrigerators
Maytag RSW24EO refrigerator not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | Refrigerators
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Refrigerators Logo
314 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
