Dvd will not eject from slo player of hitachi 19TV can you help
My daughter has tried turning off set then turning on again but dvd will not come out .Is there something else she can try?
    Problem Solver:
  • 7 Answers
Hi. There is no enough explanation about how the problem begun. If nothing like mecanism forcing or disc misplace was made it can be one of two things: electrical fail of tray or damage in mechanical parts. In both cases is better to take the set to a trained technician to try to solve the problem.
Regards,
Posted on Jan 12, 2009
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
2 dvds in built-in player
I have come across this a few times, one in fact last week!! The back needs to be removed from the back and the dvd section removed, Dont be afraid this is quite easy to do. lie the tv down face first and remove the stand and all screws, then remove the DVD section, should be 5 x screws and some leads that just clip off.
Then you will need a small screwdriver or a knife to prize the second dvd out, this may scratch your dvd but its better than your dvd player being broke!
Once out place the dvd player back in the set then re-screw it plug the leads back in and turn the set on and try to eject the first dvd, this should now be ok.
Once done, turn the tv off and replace the back on.
Just take your time and Obviously make sure the tv is not plugged in when removing the DVD.
Hope this helps
Apr 05, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
I HAVE A JVC XV-THP3 DVD PLAYER. MY LITTLE GIRL WAS PRESSING THE BUTTONS ON THE FRONT AND HAS LOCKED THE DVD TRAY. CAN YOU HELP ME PLEASE?
Hi there, I just had the same problem with my daughter, looked in the manual and it says to hold down the stop button and press the eject button on the unit. That should unlock it, its the same procedure to lock it, in case you want to prevent you daughter from attempting to play biscuits!!
Regards, darren
Jan 08, 2009 | Panasonic DVD-A110 DVD Player
Dvd player
hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
Sep 03, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
ERROR MESSAGE:
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Aug 15, 2008 | Hitachi 168589 DVD Player/VCR
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
VCR tape will not eject. "Err 2" flashes.
The unit must be opened to get your tape. Problem caused by the failure of the tape to "shuttle" back and forth to ensure no slack tape in the cassette...accordianman
Nov 07, 2007 | Hitachi 168589 DVD Player/VCR
My hitachi dz-mv730a won't eject
did u tried to press the eject button for a few seconds (~20sec) wait & see what will happen. or better you use a direct plug of AV adapter. maybe theres a need for additional power on your cam.
Sep 04, 2007 | Hitachi DZ-MV730A DVD Camcorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
