Question about Beam Industries 2900 Serenity Plus Central System Vacuum
My beam serenity plus power head shuts off as soon as it hits our carpet. It runs when held off the floor though. Do you know what could be causing this? The only thing that starts it up is the red reset button.
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: no suction beam serenity plus
You may need a new filter bag part #110346. They can cause suction problems at the unit. Either that are there is a problem with the motor, does it sound alright when running? If not, take it to a beam repair shop, with proof of purchase, the motor would be under warranty for the part only, not labor. The filter bag is not covered by warranty.
Posted on Mar 27, 2008
Agent Don
  • 310 Answers
SOURCE: BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
http://www.beamvac.com/usa/
Posted on Apr 10, 2008
ThinkVacuums
  • 144 Answers
SOURCE: Carbon buildup on plug to hose causing burn
Sounds like there could be a short in the hose. Try another hose and see if that's the problem. It's too soon to have to replace the unit. Try having the hose checked out, it could be the root of your problem
Posted on Sep 03, 2009
SOURCE: Stops Immediately. We have a Beam Serenity model
The Relay Control Board in the 2100 is bad. Replace and it should work just fine.
Posted on Feb 06, 2011
Need to change the belt but can't get into the place where the belt is
You are just not looking hard enough for the fasteners to open this up. I am not familiar with this unit but I would guess there are screws holding it together the are usually concealed in deep channels. If you shine a light in them you should see the screw heads.
Oct 15, 2013 | Beam Industries 2900 Serenity Plus Central...
My built in beam vacum cut off soon after turning it on why?
may have over heated. i'd check for clog in hose before i did anything else
Jan 14, 2013 | Beam Industries 2775 Serenity Plus Central...
Sep 03, 2009 | Beam Industries 2900 Serenity Plus Central...
Do you know what a filter bag looks like in a central air vac system?
The unit displayed is a Beam Electrolux central vacuum power unit. It has a 15litre dust bucket which does not need any dust bags.
If you take the bucket off you will notice a white shiny weighted bag hanging down. This is the filter. The good news is, it is a self cleaning filter.
Dec 03, 2008 | Beam Industries 2775 Serenity Plus Central...
Beam central vac
Don't know the exact model, but it sounds like the low voltage relay is stuck. This will be inside the unit, probably mounted on a replaceable board. You may be able to temporarily free it with a quick tap on the top of the relay if you locate it. But I would suggest replacing it to avoid further problems. mdvacuum.com would probably have the part you need. Good Luck!!
Aug 27, 2008 | Beam Industries 2775 Serenity Plus Central...
No suction beam serenity plus
Mar 26, 2008 | Beam Industries 2775 Serenity Plus Central...
Beam Industries 2900 Serenity Plus Central System Vacuum Logo
53 people viewed this question
Top Beam Industries Vacuums Experts
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
