Question about HP Compaq nx7010 Notebook
Unmountable boot volume
OS XP SP1.....nx7010....
Problem: Unmountable boot volume 0X000000ED, (OX82AFBC68,0X000009C,0X00000000,OX00000000).I can't boot from USB or CD.Can you help me?
Thanks in advance.
Vlado
  • HP Master
  • 1,879 Answers
Have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Posted on Jan 11, 2009
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
This what my laptop says, it says ***stop: 0x000000ed (0x812ace30, 0xc0000006, 0x00000000, 0x00000000) that is the technical information on the blue screen unmountable boot volume and i dont...
To repair follow these steps:
  1. Start your computer by inserting the Windows installation disk if your computer can start from the CD/DVD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
Jan 20, 2011 | Computers & Internet
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
I have the same issue and my aspire is idle for last 4 years...
Jan 12, 2009 | HP Compaq nx7010 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Unmountable Boot Volume
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
HP Compaq nx7010 Notebook Logo
580 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
