Question about IBM 9068 A01 Passbook Business Printer Serial Parallel
IBM 9068 printer error 17
Need help with my printer, can't print
4 Suggested Answers
SOURCE: Have 2 IBM 9068-A01 Dot Matrix Passbook Printer.
The cover is not shut all the way or the magnet is not making the connection between the cover and the chassis. A1 is a microcode checksum error. don't know what that means.
Posted on Mar 03, 2011
  • 11 Answers
SOURCE: I have a IBM 9068
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Posted on Aug 31, 2011
  • 11 Answers
SOURCE: IBM 9068-A01 printer loads paper crooked
Make sure it looks like this before installing. The gears have a habit of falling out of place while installing.
http://www.youtube.com/watch?v=b3u295hA06M
Posted on Sep 01, 2011
Epson WF - 7520
My EPSON 7520 printer can't print the 1m banner I buy for that purpose, it's new, I design the banner & set up to print, before print when I check for preview it's divided for 4 portion. how can I fixe it? the last size the printer it takes 27cm * 42cm long, but I need to print 27cm * 100cm what can I do? I need help.
Jul 07, 2013 | Office Equipment & Supplies
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
Can i print documents using black ink only when other inks are empty?
All the ink cartridges need to have ink in them to allow you to print, even if you only want to print in black only.
Oct 14, 2012 | Epson Stylus CX8300 Printer
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
What's your problem?Compatible printers
I think you might have installed the printer twice. If that's the case you will need to delete one because if two of the same printers are installed it confuses the computer and confuses you. Only one printer can be active and if there are two you might have printed to the one that is not active so all the print jobs when into the print queue.
Click Start/Control Panel or Start/Settings/Control Panel. Look for Printers and open it. If you see more than one of the same printer then that's your problem. Right Click on the extra printer and select Delete.
Look down at the bottom right near the time and see if you see a printer icon, if so click on it to open it. All the print jobs you tried to print will be backed up in the queue so you want to cancel or all of them.
May 20, 2012 | Gateway Computers & Internet
Please help me,, the inks in my printer are finished & i replace the black color only,, after that i tried to print a text with a black color & it dosen't print,,it show a message...
Color laser printer require that all four cartridges have toner even if you are just printing black. You will need to replace all of the cartridges that are empty before you can print anything.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP Color LaserJet 2600n Printer
Both of my ink cartridges are shown full, but only black ink prints. How can i fix this issue?
May be you have enabled Black & White printing.
You can open the printer settings and check this.
If its not possible, select 'Printers and Faxes' from start menu, right-click your printer and select 'Properties'.
Click 'Printing Preferences' and, if the Black & White' setting is selected, select 'Color'.
Click 'OK'.
Click the 'Advanced' tab and click 'Printing Defaults' and here also select 'Color'.
Click 'OK' and again click 'OK' to close the property window.
Now try printing a color document.
If you succeed, consider voting my solution.
Sep 06, 2011 | Lexmark X4270 All-In-One InkJet Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
IBM 9068 A01 Passbook Business Printer Serial Parallel Logo
562 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
