Question about Amana Side-By-Side Refrigerator 26 cu. ft. - ASD2622HR
Freezer not freezing
Freezer is just cold and not freezing , I cleaned dust and lint from under it and the fans are working . The compressor is working , so I looked at the evaporator coil and it is freezing up at the top of it , next to the defrost
    Top Expert:
  • Amana Master
  • 9,472 Answers
You will need to replace the defrost thermostat. Here is the part to order.
Posted on Dec 03, 2012
dididsaythat
  • 291 Answers
SOURCE: drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Posted on Aug 25, 2007
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
SOURCE: have an amana refrigerator model BC121VW bottem freezer
In the back of the refrigerator, there should be a vent. Put your hand over it and see if air is coming out. This will tell you if the fan the other poster mentioned is working. If no air is moving then either the fan is bad or the channel is plugged. If only a small amount of air is moving through, open the freezer door and check the air flow again. If the flow got much better, then the return channel is plugged. Try these steps, and if they help post back and I will tell you what to do next.
Posted on Aug 11, 2009
aasc
  • 1606 Answers
SOURCE: Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Posted on Jul 18, 2010
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
The fridge does not get cold
does the compressor run? If so, does it make a happy bubbly sound ? Does the door seal? Does the fan between the freezer and fridge work? If the compressor shudders when it turns off, the compressor is possibly shot. if there is dust in the grill on the back, or if it's too close to the back wall, it doesn't help. also, some fridges use the grill under the front for fresh air; so, clean all dust away from working surfaces. make sure food isn't stacked in font of the cold air vent in the fridge/freezer.
Dec 22, 2012 | Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Maytag MTF1895AEW Not Cooling
Sounds to me the compressor start relay=> 63001003 Overload=> 63001004 and Run Capacitor=> 63001005
needs replaced, the clicking noise indicates that that is the problem, Sea Breeze
Feb 16, 2012 | Maytag Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
FRIDGE WONT GO COLD OR FREEZER FREEZE, POWER TURNED ON AND FAN WORKING freezer only chills
Hello, if the freezer fan is on, there are a couple of things you can check your self if able to. Behind the unit is where you have another fan, small coil, and the compressor. There should be a lower panel you can remove to excess these. Make sure it its plugged in and the cold control is set to where it is on.The little condenser fan motor should be running. If not, touch it and see if it is very warm. If so, the motor is faulty and needs to be replaced. If it is good, check the condition of the coil to see if it is clean. Air is pulled through the front of the coil to keep the freon cool and internal pressures down. see how dirty the front of the coil is. See if it has a sheet of lint or dust blocking the air flow and clean it as good as you can. This may be the problem. After you clean the coil, look at the compressor pot, and make sure it is running. It should be warn to the touch. Carefully lay your hand on top of it. If it is off and is very hot, it is off on external overload and this is more then likely the problem. Eliminate all other things first, coil cleaning, fan on, and make sure compressor is running. Get back to me and I will let you know where to go from here. It may just be a dirty coil, which would be great.
Sincerely,
Shastalaker7
Feb 20, 2010 | Zanussi ZEBF250W Bottom Freezer...
Lec Freezer not working. Motor comes on for a few secands then goes off. Red light is on inside the freezer.
check your evaporator fan in the back near the compressor also check to see if your lower evaporaotr coil is not clogged with dust and linT! clean it and if the fan isnt running replace it! if you find it to be lint! free and the fam is working? then shell out about $200 for a new compressor
Jan 13, 2010 | Freezers
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
Amana Side-By-Side Refrigerator 26 cu. ft. - ASD2622HR Logo
65 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
