Question about Lexmark T520/522 BLACK PREBATE TONER
Out of toner
I unplugged the unit and changed the cartridge, it is still saying it is out of toner.
  • Official Brand Answer
  • 3,344 Answers
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Posted on Dec 06, 2012
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
I changed the drum unit on my c5500 printer and didn't realize that I needed to replace the toner at the same time. I just replaced that toner about a month ago and now it's saying it's empty - which I...
Before you replace a drum unit, you should (with the top toner cartridge still in place) turn the unit upside down and gently shake the toner that is in the drum unit back into the toner cartridge. When you install toner on these printers, most of the toner falls into the drum unit. The only way you can "reset" the printer is to add more toner, because there is almost no toner in that new drum.
Oct 20, 2009 | OKI C5500n Printer
Brother MFC6800-says change drum soon - is that hard to do?
yes anyone can do this, the drum is the unit the toner fits into, remove as though you were removing the toner cartridge, that the toner all the way out of the drum unit and install the old toner in the new drum and slide back into printer, again the drum unit is just the casing that your toner cartridge slips in and out of
Apr 02, 2009 | Brother MFC-7220 All-In-One Laser Printer
Will not add toner
Reinsert cartridge and restart it by unplugging or powering off
It should refresh the memory
Good Luck
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Toner empty display
If you are using the Toshiba supplied toner cartridge then properly changing the cartridge should automatically cause the unit to reset. If not, try turning the copier off, unplug it from the wall for 3 minutes then plug it back in and turn it on.
Dec 22, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toner life ends
There are two units in the machine, a toner cartridge and a drum unit. The toner clips into the drum and then is inserted in the machine. If you changed the toner and you still get this message, you may have a bad or damaged toner detection sensor.
Jun 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
New cartiage/not reconized
It says there is no cartridge, or does it say that the cartridge is empty?
First, you must realize there are two cartridges. A drum and a toner. If you bought a new toner, pulled out the drum and put the new toner in, you have pulled a DOH! You can't just put the toner in. You have to take your old drum cartridge, remove the toner portion and install the new toner into your old drum and then install the entire assembly back into the machine. I hope you didn't throw your drum out thinking it was all one cartridge (I've seen it happen). This is where reading the owner's manual helps.
If not, then one of the contacts must have been damaged. Remove the cartridge and look inside the machine. See if you can find any of the metal contacts on the side of the inner chamber that is bent or damaged and try to bend it back.
Check the drum and make sure none of the contacts are damaged.
If the unit is still saying Toner Empty, try this. On the left side of the toner there will be a while lever in a semi-circular notch.
Unplug the unit, use a small screwdriver or a key to push that white lever back to the front of the notch. Put the drum and toner back into the machine and plug the power back in.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
Lexmark T520/522 BLACK PREBATE TONER Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
