Philips 50pf9631d/37 red light blinking 7 - Televison & Video
  • 138 Answers
SOURCE: philips 42pf7320a/37 dead
I do agree with the tech but if the green led don't come on and the 7-blink error code is still there. check the connector from the logic board that will be the board under the small signal baord. The small signal board have the AV input on it. Check the connector from the logic board to the power supply there should be one connectore btween those 2 boards. On the power supply side second pin from the left it will say Vs_On if the set has 0 volts the proble is the SSB or the logic board. how to determain that is to Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU (see figure below).
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (this will supply a 100% White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Posted on Aug 20, 2008
SOURCE: red light flashes
This is a well known and very common problem with all Philips plasma tvs 42 and 50 inch. The problem is they used under rated capacitors in the power supply. If you have electronics experience or a friend that is, remove the cover and look in the back for malformed or leaking capcitors. Replace them and see if that takes care of the problem. The caps only cost $2 or $3 each, so the cost to try this is pretty reasonable although you might have an added cost of buying beer for your electronics friend. If this does not fix your problem you are down to replacing boards that can be purchased around $300 ea.
I have found my set will come on "finally" after I get the back of the set warmed up and the bad caps finally charge up. Hope this is useful.
Posted on Feb 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: My Philips 50pf9631d plasma tv turns on then red
Are you getting picture or sound at all? If not, you could have a very common power supply failure. If you get sound or picture, then you may have a faulty capacitor or resistor on one of the system boards
Posted on Aug 29, 2009
  • 8457 Answers
SOURCE: 50 in philips hd plasma with ambilight model number 50PF9631D/37
The backlight inverter board is going just not dead yet.
U need a new board.
Posted on Sep 10, 2009
  • 11 Answers
SOURCE: why does my philips 42pf9361d/37 power light blink
something in the power supply. its been said its a common problem with Philips TV's. there is most likely two blown caps on the power supply. do a google search and im sure you will find a forum with pics and info. if you dont have the ability to solder new caps to the board take to your local tv repair shop.
Posted on Nov 04, 2009
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
7 red blinking light. Tv not turning on. I replaced the 2 blown capacitors
The caps you replace was it from the power supply or the mainboard?
Thanks
Nov 22, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My 50 in philips ambilight plasma will not turn on and blinks a red light 7 times and repeats
The failure with your plasma is with defective capacitors in the power supply.
Check the link below with info on how to DIY.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Jul 16, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Seven red blinking led
Check the link below to find the parts that are causing the LED to blink 7 times and replace them to fix the plasma.
Jun 14, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a philips 50'' television, model #50pf9631d/37 with a flashing red light on power light, sometimes i unplugged the unit about 5 or 6 times for about an hour, then try to turn it on quickly with the...
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
Dec 31, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My Philips 50pf9631d plasma tv turns on then red light blinks 7 times! Philips no help. Local electronics store wants $500 to fix! Set is only 3 yrs old! Please help.
Aug 29, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
