Question about Canon Pixma MP800 All-In-One InkJet Printer
Canon Pixma MP800 not scanning - error code 2,155,0
My aging Canon Pixma MP800 stopped scanning (printing/copying ok) and showed an error message 2,155,0 (not connected, cable missing, etc.) Tried (many times) all the usual recommendations (different USB port; better, shorter USB cable, update drivers, etc, re-install software, etc.) all to no avail. Was about to replace printer when I noticed a suggestion that turning off User Account Control would solve the problem. It did, but obviously this leaves my Windows 7 desktop less well protected. Switching between UAC on and off is not a practical solution. Whatelse can I do to scan without turning off UAC?
5 Suggested Answers
marked
  • 6487 Answers
SOURCE: Canon Pixma ip5200 get Document
Do these following steps to correct the problem.
Click Start > RUN type there CMD hit enter then on the black screen type NET STOP SPOOLER hit enter, Then wait for about 30 seconds then on the black screen type NET START SPOOLER and hit enter then once the service is started try to print again.
Posted on Aug 26, 2010
SOURCE: Scanning error - cannot scan error code 2,155,0
buy a proper usb cable..the one with the filter
Posted on Oct 12, 2008
vegakitten20
  • 685 Answers
SOURCE: Canon Pixma MX310 won't scan or print
try unplugging it for a little bit then plug it back in and try again if this doesn't work then do a fresh install
Posted on Nov 19, 2008
muntejaya
  • 10421 Answers
SOURCE: Scanner driver not installed is the error message.
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay klacrw
Posted on Feb 12, 2011
Error 2,156,50 canon mg 2120
because I can not always quick scan shows me the error 2156.50
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Canon mp130 shows error "
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Jan 26, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon printer pixma mp110
how can i reset canon pixma mp 110 tahnk you please help me
Jun 02, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 6A00
TThere is a prblem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Send the printer for repair ,
Apr 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP800
you need to clean and calibrate them..you'll need to do that from the print manager, under maintenance
Apr 14, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA MP130 'waste ink absorber' message
If the error message is ""ink waste absorber almost full"
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing OK
4)Enter ABS-M LEVEL by pressing <--- or ---> then OK
5)SET ABS-M LEVEL TO 0
6)OK
7)STOP/RESET"
If the error message is "" bottom ink waste absorber almost full"
Set "ABS-P" level to 0. Then "OK" and "STOP/RESET"
To clean the absorber, open the cover, and there are 2 small pads under where the cartridges normally sit. Put a pad of absorbent kitchen towel on top of the pad and press down a few times. The towel should absorb most of the ink. To give it a really good clean, turn the printer upside down while holding the kitchen towel over the pads and press a few times. You'll get more ink out.
It's a good idea to wear disposable gloves when you do this.
Apr 07, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
