Question about Sharp DUNTKE558FM01S
My sharp lc-46D64U ONLY TURNE BY PRESS THE VOL- AND IMP, AT THE SOME TIME THAN GOES OFF IN 2 OR 3 SEGUND
MY SHARP LC-42D64U ONLY TURNE ON BY PRESS THE VOL- AND THE INPUT AT THE SOME TIME, THAN GOES OFF IN 2 OR 3 SEGUND, THE LETTER K APPEAR ON LEFT SIDE OF SCREN, THE PICTURE GOES OFF BEFOR THE SOUND PLEASE HELP ME THANKYOU
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
Russmann
  • 203 Answers
SOURCE: Sharp Aquos LC-20B6U-S TV NOW
This can be caused by many different things. Check power supply fuses. If ok suspect inverter board which drives screen. Check for bulging capacitors and open transformers or just find replacement cost using numbers on board. That may fixya.
Posted on May 29, 2008
Russmann
  • 203 Answers
SOURCE: Sharp model LC-20B6U-S now has
By this description it sounds like you have backlight to the picture which means the power supply in the set is working and the inverter board which powers the screen is working. Your problem may be on the main board if this is the case. I have repaired this set for the same symptom with two different problems. First it could be on the inverter board, and second it could be on the main pcb. Once on this model a piece of metal heatsink slid down due to operating temp. of set and touched bottom of main pcb causing a failure of the sound and picture. Either way, if you have no on-screen-display you will be replacing a circuit board. If you whine loud enough to the mfg. co. they may help you. But good luck.
Posted on Jun 02, 2008
SOURCE: I recently purchased a Sharp
I think the USB port is just for software updates.
Posted on Jul 29, 2008
Benimur
  • 6966 Answers
SOURCE: we have a dish sat.
Depending on how the satellite receiver is wired to the Sharp TV. I suppose your best try would be to select the input source on the Sharp, something like AV1 or Video (1) not channels. Channel selection would be done on the remote of the satellite receiver.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 15, 2008
WHAT CAUSES SHARP LC-46D64U LOW VOLUME
check on all inputs to see if any are normal or not--this will point to where or what the problem is.
Aug 27, 2012 | Sharp LC-46D64U 46 in. LCD HDTV
Sharp lc 46D64U - Audio out seems right channel of output not functioning. I switch cables over and there is no sound on right side. Is there any others with this problem. Will a reset of system cure this...
Check your user menu in the audio functions and make sure your balance is set properly. Also check the resistance of your speaker. It probably needs replaced.
May 18, 2012 | Sharp LC-46D64U 46 in. LCD HDTV
How to reset sharp aquos lc-32l400m?thanx before
Sharp Aquos LC-32L450M - i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritating please any one help.. wats the problem
Jan 06, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Need details of sharp tv
Get the correct model number first and download the user's manual from Sharp. I think you meant LC-46D64U.
Apr 11, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have for the first time hooked a sharp aquos LC-46D64U to my basic Direct TV cable (Not High -Def) and the picture lookd all ghosty and watery. I tried adjusting the picute controls and it seems to have...
A 46'' TV is zooming all the defects, to make sure is not a problem with your tv, try with a DVD Player using at least a set of Component cable or HDMI will be the best way to test it.
Dec 06, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Can not power it on, the power LED keeps blinking.
Most likely, the power board was defective. You need to replace it.
Aug 18, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Sharp lc-46d64u broken screens
if the screen is broke its not worth the repair
Dec 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos Audio Intermittent
This is a problem with the ATSC channel's reception. Usually switching to another channel and back solves the problem.
Jul 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp DUNTKE558FM01S Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
