Question about Pride Mobility Jazzy 14 XL Extra Large Power Chair - Used Electric Wheelchairs
I charg my chaire for 8 hrs and it dies in 20 minnuts
I charge over night and it dies in 20 minutes the barites are 6 months old
  • Pride Mobility Master
  • 1,271 Answers
Firstly can you try another charger ?
it either the charger or Batteries , there is a remote possibly that the controller is faulty and leaking to ground but that's very rare plus you smell it when going along.
Regards
Posted on Dec 11, 2012
My chair will not charge,chkd all connections,good.chair has not been used or charged for at least 2 years.it is a2009 chair.
Those batteries may be 8 years old and is probably time for replacement. Batteries should be charged regularly or they will die and not recharge if left. Go to a battery store and get them checked out.
Jun 19, 2017 | Health & Beauty
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
My chair has been sitting for 4 months in garage. Chair MPV5 was rarely used. When charging, battery charger indicator shows green light. Chair still does not turn on. What should I be doing?
Replace the batteries and charge before use then charge nightly for 20 days Use the chair daily so you can get a good charge nightly to get the batteries operating at 100% After the 20 days If you don't use the chair daily always store fully charged and then charge once a week overnight. Should work fine once you get the new batteries in You will need to get 2 U1 batteries for your chair do not get Wally World or automotive batteries You must replace with sealed deep cycle batteries made for power chairs Hope this helps
May 07, 2011 | NRS Hoveround MPV 5 - Used Power...
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
Batteries will not hold charge very long???? almost brand new power chair will not hold a charge and has only been charged a hand full of times???
anthony thats the problem batteries seldom used will not be broken in correctly and will get weaker rather than stonger. charging a handful of times will not do it. MK batteries recommends that new batteries be charged nightly for 20 days to break them in. Sorry you will have to get new batteries. Now new batteries usually have a 6 month warranty and if its been less than that try getting them replaced via warranty through the provider that sold you the chair Hope this Helps
Oct 03, 2010 | Pride Mobility Products Health & Beauty
Why would my less than 2 months old batteries die after 15 minutes run time?
Has your power chair been stored or not used in a while? Have you been charging the batteries regularly? Is the charger plugged in to a working electrical outlet, turned on and plugged into the power chair properly?
If the batteries have not been maintained properly, they may have become damaged that will prevent them from getting a full charge. It can happen quickly, even in as little as 1 month of storage.
When you operate the power chair is there any noise or vibration that could indicate a mechanical problem?
If you continue to have a problem, contact your dealer or manufacturer. If your insurance paid for the power chair, they may pay for repairs. Warranty may not cover repairs caused by customer neglect.
Aug 06, 2010 | Ctm HS-2800 Power Wheelchair
Had new batteries and a service 6 months ago. Has now been left standing for a couple of months. I charged it up last night, but nothing. The charger appears to be working, lights working. Any ideas
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Feb 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Phone dies completely when on standby for more than 20 minutes
You need to take the phone and have the firmware reflash
Dec 08, 2008 | LG Vu CU920 Cellular Phone
Pride Mobility Jazzy 14 XL Extra Large Power Chair - Used Electric Wheelchairs Logo
Top Pride Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Scooter Doctor
Scooter Doctor
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
