Question about Brother Sewing Machines
I have the brothers LS-1520 the needle wont stay up even after i adjusted the screw.
  • Brother Master
  • 7,365 Answers
Sounds like the screw has stripped out and you need a new one. or
it could be the needle clamp that is stripped out, it would be a good
idea to have the machine checked to see which one it is.
Posted on Dec 03, 2012
  • 76 Answers
SOURCE: brothers sewing machine ls 1520
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
Posted on Aug 28, 2009
  • 18 Answers
SOURCE: I would like to adjust the timing on my sewing
with the timing you are better off to taking it to sewing machine mechanic it may cost you more by doing it yourself
Posted on Nov 24, 2009
SOURCE: needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Posted on Dec 15, 2009
  • 255 Answers
SOURCE: how to wind a bobbin on a brother LS-1520
Hi. You can get a manual for your machine from http://www.brother-usa.com/Support/ (scroll down to Manuals and Documentation). The manual will have all this information for you.
Happy Sewing!
Robbie
Posted on Mar 05, 2010
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
LS-1520 my needle wont stay up even after i adjusted the screw
it's possible that it's the needle clamp or the needle clamp screw
that may be stripped out, a repair shop can tell you for sure.
Dec 03, 2012 | Sewing Machines
I WAS sewing and my needle hit a pin and know the top thread will not catch the bottom thread
Hi joanncastro6...
Sounds like you have a bent needle...I recommend that you replace your needle and that should solve your problem.
Please take time to rate me
Jul 31, 2011 | Brother LS-1520 Mechanical Sewing Machine
Can't get new bottom bobbin to catch with the top needle.
Try a new needle, sometimes there is a burr on the needle that is hard for you to see. Make sure that the flat side faces the rear of the machine and is inserted all the way up.
Jan 02, 2011 | Brother LS-1520 Mechanical Sewing Machine
Brother LS 1520 I was in zig zag mode and broke a needle. Now that I have replaced the needle, the needle thread will not pick up bobbin thread.
Are you sure that you replaced your needle right? The flat side must face the rear of the machine and did you put your needle on a straight stitch? I hope it didn't mess up your timing. But try this and I have my fingers crossed for you that it is something simple.
Dec 11, 2010 | Brother LS-1520 Mechanical Sewing Machine
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
I would like to adjust the timing on my sewing machine it is not picking up any more can you send me instructions for a brother ls-1520
Nov 24, 2009 | Brother LS-1520 Mechanical Sewing Machine
I have only used this machine twice, but now the needle hits the plate when it comes down...what could be causing this? and how can I fix it?
You could have a bent needle. Check and see if the needle is straight. If so, you need to take the machine in to adjust the lineup. Your machine should not be hitting the needle. Make sure you have the thread from the sewing thread threaded correctly, If it is not it will not sew correctly. Your bobbin should also be threaded correctly, some bobbins go clockwise and some go counter clockwise. Sheck your manual for the correct placement. You should also change your needle everytime you start a new project. The needle is important for smoothe sewing.
Oct 03, 2009 | Brother LS-1520 Mechanical Sewing Machine
Brother won't sew
My Brother machine is sensitive. You may have already done this, but...
Rethread the top, following diagrams and instructions precisely.
I have taken the front off the machine to find a nest of thread in the upper part of the machine.
Remove the bobbin and bobbin case, and reseat both.
Check the needle. If it is bent even slightly or not seated well, the whole needle shaft can lock up.
FAQs Troubleshooting LS 1520 Others Brother
Aug 11, 2017 | Brother LS-1520 Mechanical Sewing Machine
Zigzag
When using your zig zag are you readjusting the needle from 0 either to the left or right, if you dont adjust the left/right margins the needle will stay straight and wont zz even though you have one of the selectors on zz you need both readjusted should be a small dial or lever on the machine and when you move it you will see the needle move as well
Sep 04, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
