Question about Microwave Ovens
Kenmore Microhood not working
My Kenmore Elite Microhood just stopped working. No power, no nothing. It has power from the outlet, but no power in the system at all. I was using it to cook potatoes and it just stopped in the middle of cooking. Service man thought it was a fuse, it was not, all fuses are good. Any help with this would be appreciated."
  • 979 Answers
I think it may be an internal fuse or a fusible link. You also have a series of contacts and switches inside that are set in place by the mfr. for safety. You could get it repaired for 50-75 dollars or a new one for 125-150 dollars. If you have checked the internal fuse, then just get a new one if the other one is older than 3-4 years.
Posted on Jan 11, 2009
Frigidaire microwave
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
Code, F-9
This is not usually a consumer repairable fault - but you may be able to clear it simply by unplugging from the outlet for a minute or two and plugging it back in again. Try it out and if it works, you're all set - otherwise it might need to be seen by a pro.
Apr 07, 2014 | Kenmore Elite Over The Range Microhood...
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 22, 2008 | Kenmore Microwave Ovens
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Kenmore microhood model 721.80833500
our tray that goes around and back and forth jumps the tracks and stops and turns the other way I can put it back on track before it makes a round it jumps the tracks again and starts going the other way is there a part that need replaced
Jan 13, 2008 | Kenmore 80809 Microwave Oven
Turnaround glass tray problem
Sometimes they get heated up and bend up in the middle so they don't make good contact with the coupler. The way I fix this is to heat the support over a stove flame, then place a heavy weight on it so it holds the legs up in place a bit until it cools. Here it is step by step: 1. Apply heat at points where each legs meet the hub (stove flame) 2. Place end of each leg on an object so that the bottom of the hub is held up about 1/8" off the work surface. 3. Place heavy object on hub so the bottom touches the work surface. 4. Let it cool. 5. Test it. 6. If it still does not work, increase the height of objects in step two. See: http://207.234.249.73/mwd/turntable_support_fix.gif
Mar 26, 2007 | Kenmore 80809 Microwave Oven
Microhood turntable not working
You can find an exploded view of your microwave at http://www3.sears.com (yes, the 3 is there). Ref # 3009 on the drawing is the turntable motor. I would grab it by the shaft and gently try to turn it. If it's locked up or grinding, that's a sign it's bad. It runs $24.49 plus shipping: Part Description: Quantity: Part Number: Model Number: Price: TT MOTOR 6549W1S013D 721.64663300 $ 24.49 $ 24.49 Be sure to unplug the oven before you work on it. Hope this helps!
Dec 01, 2006 | Kenmore 63763 Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
