Question about LG Microwave Ovens
Lg lmlv2055sb just stopped working
We have a 6 year old, LG LMVM2055SB over the range microwave. It has been great all this time. After cooking 3 baked potatoes it just stopped working. The plug still have power but nothing powers up at all. I was able to get to the fuse and it has continuity. Not sure what is next or if this is just a throw away machine at this point.
    Top Expert:
  • LG Master
  • 14,553 Answers
6 years may be the point where the repair could cost more than a new unit----Call a local shop to see what it costs to look at the unit and if possible get a ballpark estimate---then weigh repair versus replacement.
Posted on Dec 04, 2012
5 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Posted on Nov 18, 2007
  • 202 Answers
SOURCE: Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Posted on Aug 05, 2009
  • 10865 Answers
SOURCE: My LG over the range microwave doesn't heat any more
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
That said, you can get free estimates on the cost of a repair but you should also consider a replacement which may be a better option for you.
What they do not tell you about over the stove microwaves is that they are constantly deteriorating due to the steam, oil, and other cooking fumes from the stove below. As a result, their life expectancy is definitely diminished.
Posted on Aug 19, 2009
  • 8909 Answers
SOURCE: We got LG combination microwave
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 22, 2010
We have a 3 year old Cooke and Lewis integrated microwave/grill that has recently stopped working. It starts up but after 5/6 seconds it stops and 'err 5'comes up on the display. Any ideas?
if this was purchased from the likes of B&Q, at the time of purchase, the retailer must ensure that the goods are/were fit for purpose for a period of 6 years from date of purchase. This is regardless of manufactures warranty. Take it back, demand a new one, quoting the above
Jan 02, 2016 | Microwave Ovens
My LG over the range microwave makes a rattling noise when I am cooking. The sound is not there is the item I am microwaving is heavy.
This may sound a bit nuts, but remove the glass tray and support ring. Clean the wheels and ring. Also clean the glass and microwave surface where the wheels run. Any tiny bit of debris will stop the wheels from turning, and make a rattling noise.
If that doesn't help, you may need a new turntable motor.
Feb 26, 2011 | LG Over-the-Range Microwave
My over-the-range LG microwave stopped working yesterday. At first the display said "set time", but nothing happened when I touch the key pads. Now the display is jut the colon between the hour and minutes...
LG would still fix it if you are ready to pay for their service. Again, if the oven is JUST out of warranty, they may fix it for free. But it hugely depends on the pressure you exert on them and the number of calls you make.
Oct 23, 2010 | LG Microwave Ovens
Maytag Microwave apprears to work but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
I have LG over the range microwave and the keypad will not let me enter 0's. Such as 2:00 minutes cooking time. I can enter 2:25 but the keypad will not accept 0's.
Its just a problem with that button on the touch pad, gonna have to take panel off and check the connections could be a burnt wire or broke wire.
Sep 03, 2009 | LG Over-the-Range Microwave
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
Microwave will turn off a few seconds after start.-
It seems there is something wrong either with the builtin controls or the buttons. It needs to be examine by a professional.
Oct 31, 2017 | LG Over-the-Range Microwave
Lg microwave LMV1650ST
don't try to fix this yourself, faulty microwaves should be repaired professionaly or replaced.
Oct 23, 2008 | LG Microwave Ovens
Nov 18, 2007 | Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
