Question about Sewing Machines
LS-1520 my needle wont stay up even after i adjusted the screw
I just went 2 put the needle in and it just wont stay up after i adjusted it.
  • Sewing Machines Master
  • 7,365 Answers
It's possible that it's the needle clamp or the needle clamp screw
that may be stripped out, a repair shop can tell you for sure.
Posted on Dec 03, 2012
5 Suggested Answers
  • 26 Answers
SOURCE: LS-1520 clamp won't secure needle in place hits
maybe the needle was not inserted all the way in and that is what is causing it to seem like the clamp is not holding the needle in. is it eh right needle is it turned the right way flat side to back??
Posted on Mar 08, 2009
  • 52 Answers
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Posted on Jul 14, 2009
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
  • 1788 Answers
SOURCE: Brother LS 1520 I was
Are you sure that you replaced your needle right? The flat side must face the rear of the machine and did you put your needle on a straight stitch? I hope it didn't mess up your timing. But try this and I have my fingers crossed for you that it is something simple.
Posted on Dec 11, 2010
I have the brothers LS-1520 the needle wont stay up even after i adjusted the screw.
sounds like the screw has stripped out and you need a new one. or
it could be the needle clamp that is stripped out, it would be a good
idea to have the machine checked to see which one it is.
Dec 03, 2012 | Brother Sewing Machines
Brother LS 1520 I was in zig zag mode and broke a needle. Now that I have replaced the needle, the needle thread will not pick up bobbin thread.
Dec 11, 2010 | Brother LS-1520 Mechanical Sewing Machine
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
I would like to adjust the timing on my sewing machine it is not picking up any more can you send me instructions for a brother ls-1520
with the timing you are better off to taking it to sewing machine mechanic it may cost you more by doing it yourself
Nov 24, 2009 | Brother LS-1520 Mechanical Sewing Machine
I have only used this machine twice, but now the needle hits the plate when it comes down...what could be causing this? and how can I fix it?
You could have a bent needle. Check and see if the needle is straight. If so, you need to take the machine in to adjust the lineup. Your machine should not be hitting the needle. Make sure you have the thread from the sewing thread threaded correctly, If it is not it will not sew correctly. Your bobbin should also be threaded correctly, some bobbins go clockwise and some go counter clockwise. Sheck your manual for the correct placement. You should also change your needle everytime you start a new project. The needle is important for smoothe sewing.
Oct 03, 2009 | Brother LS-1520 Mechanical Sewing Machine
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
LS-1520 clamp won't secure needle in place hits pressure foot and breaks
Feb 27, 2009 | Sewing Machines
Brother won't sew
My Brother machine is sensitive. You may have already done this, but...
Rethread the top, following diagrams and instructions precisely.
I have taken the front off the machine to find a nest of thread in the upper part of the machine.
Remove the bobbin and bobbin case, and reseat both.
Check the needle. If it is bent even slightly or not seated well, the whole needle shaft can lock up.
FAQs Troubleshooting LS 1520 Others Brother
Aug 11, 2017 | Brother LS-1520 Mechanical Sewing Machine
Zigzag
When using your zig zag are you readjusting the needle from 0 either to the left or right, if you dont adjust the left/right margins the needle will stay straight and wont zz even though you have one of the selectors on zz you need both readjusted should be a small dial or lever on the machine and when you move it you will see the needle move as well
Sep 04, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
