Question about Dell U2711 Monitor
U2711 display problem on the right half : image moves to the left
The right half of the image moves a little bit to the left (something about 5mm) for just an instant. Problem occurs randomly : sometimes 2 or 3 in 1 minute ; sometimes 1 in 30 minutes tested 2 different graphic cards, 2 different dvi cable, and different refresh rates. I know u2711 display uses 2 chip to process the high definition. One for the half left and 1 for the right so it explains why a lot of problem concerns only one half of the display. Thanks in advance for an idea ...
  • julien Dec 07, 2012
    Thanks for the help, but i'm quite sure display drivers are not involved in this problem. It is a physical problem, as bad connection, bad wire, bad capacitor, interferences or something like that. A video on youtube called " Dell U2711 monitor problem" show exactly the same problem, except mine is a hopefully lot less frequent
I have the same problem and this is how I found your post.
I suspected both cable & display board so changed both to no avail.
Searching in google "flickering streaks dell u2711" I found the cause and the solution here:
http://www.youtube.com/watch?v=_En6ih88uws
This may be too late or inadequate for your specific problem but as it may help, I still post this potential answer.
I have contacted Dell support to ask if I can have a try at "repairing" (cleaning connections & spraying anti-oxidant) myself without losing my maintenance contract otherwise I have to stay too long without this otherwise excellent monitor. I am an ordinary user, not a technician, but this solution seems simple enough if careful.
Regards
paul
brussels
Posted on Mar 02, 2013
  • Dell Master
  • 8,457 Answers
Tries Dell website to upgrade the latest software for the monitor for stablitation and compabilities.U check the compabilities with the OS Win 7 or 8 for drivers that work best and for the 2 graphic cards u are using.
Posted on Dec 03, 2012
3 Suggested Answers
bassplayer97
  • 154 Answers
SOURCE: LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Posted on Jul 11, 2009
frankgilbert
  • 613 Answers
SOURCE: the image on my dell U2711 ultrasharp monitor
Well if you have a warranty please send it back before you damage it and then don't get anything. See if it has a screen reset button on the front or back such as factory reset. Hope this helps.
Posted on Jan 05, 2011
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
Jun 25, 2012 | LG 42LE5500 42 in. TV
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
Image does not fit screen
Set your setting to "Secondary Screen Only"
As your setting for both screen doesn't seems to be adjusted but you can try turn it off.
Jul 26, 2017 | Samsung SyncMaster 172N 17" LCD Monitor
Xbox 360: how to move screen image?
are u using a lcd or a crt television
Sep 29, 2008 | Microsoft Xbox 360 Console
I am a real novice and would like to know how to fix the pixils for a more defined image.
right click on desktop/wallpaper,properties,settings,it should be 32 bit and around 1024x768 resol
Jul 31, 2008 | Computers & Internet
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Double vision
it looks like when you took this apart you did not alignt the lenses properly, there should be a locating groove or stub which these lenses should fit to... it looks like they are pressing against the stub but are not located properly, hence the distortion. try taking it apart again....when you put it back together again the fault may have gone.
Sep 29, 2006 | Wesco WS7 Microscope
Dell U2711 Monitor Logo
276 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
