Inop rc25 Changed batts, but still will not work, guess it needs to go away for repair, can anyone help
    Top Expert:
  • 14,553 Answers
If you are talking about the remote itself any shop can test it without the unit and most do that for free.
Posted on Dec 03, 2012
1994 E150 van ford no alt power have changed the alt. charged the batt
There is a fuse or fuseable link between the alt and battery, and the alt gets a signal from the key to activate the voltage regulator.
I would check for batt voltage at the alternator and you may need a wiring diagram to check for key voltage.
Jul 02, 2012 | Ford Cars & Trucks
My fitflop boots are in excellent condition but they need a new sole as it has just started to wear away on the heel area I cannot find anyone who repairs these any ideas as to who I can contact to ha
I would say that most better quality shoe repair shops can do this work. If the ad in the yellow pages says something about doing orthopedic work, I would hazard a guess you have the right place!
Feb 04, 2012 | FITFLOP Clothing Accessories
2000 saturn radio is locked. how do i unlock
1.) To begin, if your radio is displays LOC, then proceed to step 2. If your radio says INOP, then turn your ignition to the RUN position, and turn the radio ON. You must leave it like this for a minimum of 1 hour (not 59 minutes) to clear the INOP message. I would wait 1 1/2 hours just in case doing it too early causes the timer to start over.
2.) Turn your ignition to RUN (if not already), and your radio to OFF. Press and hold preset buttons 2 and 3 for around 5-10 seconds to obtain a scrambled version of your radio's original factory set code.
3.) Call a GM dealer with this code. Tell them you are with a local shop i.e. I am Joe with Good Year Highway Tire; Then tell them: We have a 2000 Saturn SL we just changed a battery in and the radio is now locked. My mechanic pulled the pre-code. Could you give me the code? This usally works at no charge.
Once you have the code write it down. Keep atleast 2 copies. Hope this helps!
May 06, 2010 | 2000 Saturn SL
2001 Dodge Caravan Check Engine Light wont go away
i would try a coil pack maybe you got a bad one . did you clear the code after you changed the parts . disconnect the batt for ten sec
Oct 20, 2009 | 2001 Dodge Caravan
I have a 94 olds cutlass cierra and the fans dont work
Check fuses, relays, the hook fan straight to batt power with jumper if fan is inop replace. If it works find your wiring problem.
Sep 21, 2009 | 1994 Oldsmobile Cutlass Ciera
My 1992 chevy camaro rs fan doesn't work
Hook fan up to Batt power. if it work check fuses and relay. if no problem its a wiring problem. If fan is inop replace it
Sep 21, 2009 | 1992 Chevrolet Camaro
Lens wont stay open.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK OoW repair is 48,44 +shipping to the repair centre:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 03, 2009 | Kodak EasyShare M863 Digital Camera
Horn and heater fan inop
check the fuse.I think they are on the same fuse/
Aug 27, 2008 | 1994 Suzuki Samurai
Power/battery problem
just log on to support.dell.com
click on drivers and download
punchin your system's servica tag
download BIOS updates
but it will only be done if ac adapter and battery are both connected if its not
than it could be an issue with the systemboard and will be replaced if you live in US call 1-800-624-9896(DELL)
Apr 18, 2008 | Dell Latitude P4 C640 Business Laptop...
 Grubhead
Grubhead
