Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer error what is error e9e
  • 943 Answers
Hi The codeE9E means theres a problem with the voltage going to the motor. this is a complicated one I would call a tech to look at the dryer, thanks
Posted on Jan 11, 2009
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: my affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Posted on Sep 27, 2010
  • 3 Answers
SOURCE: error code E9E
E9E stands for low voltage and/or intermittent power. At least that's what the "training" manual said.
However, my dryer was overheating to the point of the back being too hot to touch. The service rep with Best Buy told me the error message made no sense. Computers aren't so great. My dryers only three years old. My previous "analog" dryer ran forever.
Posted on Nov 16, 2008
localwonder
  • 6784 Answers
SOURCE: Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Posted on Jun 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
Frigidaire dryer error code e9e
Hello zabbster - Typically E9E means that there is an issue with the control board receiving low or intermittent voltage and you would need to contact a professional to verify the house wiring and confirm the power supply.
Sep 25, 2012 | Frigidaire Dryers
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
What is error E9E ans E4A?
this is a line voltage error. press the cancel button for three seconds un plug the unit and have the main power plug checked for the proper voltage and insure that your wires are correct on your dryer
Oct 06, 2009 | Dryers
I keep getting a E9E error code on my Fridgidaire gas dryer. It starts, then stops and flashes the code
this is a line voltage error code press the cancel button for three seconds check you power and make sure the power supplied is correct.
Sep 12, 2009 | Frigidaire Dryers
Jun 09, 2009 | Frigidaire Dryers
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
Jun 05, 2009 | Kenmore 62602 Electric Dryer
Apr 25, 2009 | Kenmore 67082 Electric Dryer
My affinity frigidaire dryer keeps flashing an E9E error code
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I get an E9E fault code on my two year old Frigidaire front loading dryer.
Sep 08, 2008 | Frigidaire Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
281 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
