Question about Sharp Televison & Video
I have a sharp aquos 32 my son has ripped out the input bit can i solder back on
    Top Expert:
  • Sharp Master
  • 14,553 Answers
It can be replaced but if part of the tuner a bit tricky for a novice---a suggestion:
If the set has audio/video input jacks on rear---use a cable box etc to route the signal into those--select that input and change channels with the box--------you can even use a old vcr and connect your signal to it and route it that way---get around the issue.
typical repair if the tuner itself is not damaged (fitting goes into it) can average over 100 dollars and double that if tuner has to be replaced----if you get the fitting replaced get a slide on adapter for the end of the coax so if it gets yanked it will slide off......
Posted on Dec 03, 2012
SOURCE: Clean screen
I used the Monster "Screenclean" kit, which left a film on my screen. I am not happy with it. Any suggestions on a different product which will remove the film?
Posted on Jun 06, 2008
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Posted on Jun 12, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
SOURCE: My sharp aquos 32' LCD has a heavy green tint to
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Posted on Mar 15, 2010
My Sharp Aquos Lc32d62u 32-inch HDMI Inputs are not working
T-CON has absolutely nothing to do with HDMI inputs.
it's like changing the front wind shield of a car because it doesn't turn on.
You have a particular IC failed on the main board of your Aquos - maybe more than one - likely due to a power surge through the signal cable.
A replacement of the main should fix that, if not component level repair, but considering this is 32'' unless you have someone really handy around you to help I'd say you'll be better off replacing the whole main board.
Oct 12, 2012 | Sharp Aquos Lc32d62u 32-inch 1080p Lcd...
Sharp lcd tv 32 400m. pc input problem, can't fungtions input 5 (blur)
i connect tv cable but vedio is not working only audio is working in top K letter it is showing in screen
plz send solution
chakradhar
9440176800
india
Feb 01, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp aquos no sound through hdmi
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
I have a sharp Aquos and the input button will not come on black
If you get sound but no picture (black screen), There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Oct 10, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My sharp aquos picture has got bright(luminous)green edges to all images.fine until today.less than 2 years old.help
Sharp Aquos is a bit like saying Ford Estate . Without the model advice is a bit bland
There are know issues where the digital decoder can cause the main software to crash.
Although its not a DIY fix the updated software and a reset is often the cure fir this kind of issue,
If it is a software issue its the kind of thing we do over coffee break!
Jun 22, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos 32" lcd hdtv, looses video, audio still works.
that's D44 serial common problom,the cables connected to the panel made the problem
Mar 23, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-46D64U need to replace broken tuner
actually you dont need the tuner you just need the rf connector itself which you can easly pick up at a radio shack for a few bucks. you can DIY it will take a bit of soldering and time. First take the broken connector to radio and look for a close match, longer leads better you can always cut to fit.
remove board from tv and un solder the tuner. if solder does not seam to melt apply some fresh solder and then unsolder. pop the tuner lid of carefully both top and bottom to gain access to the circuit. cearfully remove any remains of the old connector. Now find the hole where the last part was and insert new RF connector adjust and cut the lead if nessary and resolder to circuit. place both caps back on and resolder tuner to board.connect board to ther circuit and test.
Mar 17, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Televison & Video Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
