Question about Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer
SAMSUNG WA5451ANW/XAA WATER NOT FILLING TUB. KEEP GETTING ERROR CODES; L22F, E2 OR NF?
4 Suggested Answers
pride applia
  • 232 Answers
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
  • 274 Answers
SOURCE: My samsung front loader is only 6 months old and
what do you maen its not filling? is it washing is there a full load?has any thing chaned or are you doing any thing different when you got it? check and make sure the fill hose is not kinked the valved is on all the way. try these and let me know.thanks
Posted on Aug 29, 2010
rylee_smith
  • 8619 Answers
SOURCE: I get an NF error
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. Try running the diagnostic test by:
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 22, 2010
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
There is no power samsung wa5451anw/xaa-0002
hum not good
sounds like something has fused and blown the mains
you need to look too a control board error for this ...
its a job for a tech,... for sure..
Mar 05, 2015 | Samsung WA5451ANW 4.7 Cu. Ft. White...
Samsung washer had ND code, checked for clogs, could not find a filter on my machine, drain pump is in back inside panel, I removed hoses and found nothing, now machine will not start a cycle or drain, no...
to start with for your first problem "NF"if u Insert the drain hose too far into the drain it may cause a syphon effect stopping any water from draining out of the washing machine. and that will cause an "Nd" error.and 6e9df0b6-14e5-4444-9dca-eea3526ce7ee.jpgmake sureto the make sure there is power to the washer and if there isn't there is a good possibility it is the
Bearing Seal and Bearings:
May 26, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Samsung washing machine nf Error code
Here is the best troubleshooting manual i've ever seen. It's PDF:
http://downloadcenter.samsung.com/content/UM/201106/20110628141933509/WF350AN-Tech-02834A-02.pdf
I found it here:
https://www.samsung.com/us/support/owners/product/WF350ANP/XAA
NOTE: If water is not entering tub, you almost certainly need to replace the water valve. If water is entering tub but won't fill your drain pump is suspect. Hope this helps.
Dec 30, 2012 | Samsung WF350ANP Front Load Tumble
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
A desplay of nf on read out
For the FAV6800A NF error code is no fill. Could be a bad Water Inlet Valve. Does water run into the machine at all with the water temp seleced/wash cycle selected?
Try a hot selection if you are filling with cold and see if you fill the wash tub.
If you need to do additional troubleshooting help you need to go to a true DIY forum to get the FAV6800A Service Manual. Post back if you want to DIY the fix.
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
Nf error code
If there is no water in the wash basket/tub you may have a bad water inlet valve. Try filling with a water mix Hot/Cold will the wash tub will fill and proceed.
If you need further troubleshooting support post back...........**** or Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Dec 31, 2009 | Samsung WF206ANS Front Load Washer
Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Logo
441 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
