Question about Admiral AW22 Top Load Washer
How can I bypass lid lock
To see if tub is moving while agitating
    Top Expert:
  • Admiral Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
Real solutions do it yourself not pay a professional. this should be a simple fix!!!
Posted on Dec 29, 2013
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
We have a Kenmore Elite clothes washer model 110.2494 purchased in 2003. Every time my wife washes sheets (either 1 or two king size) they twist into a tight rope. Some research suggests that replacing...
Start the washer. Once it begins agitating raise the lid and observe the tub.
The agitator should be going back and forth.
The tub should be stationary.
If he tub is moving also,you have a bad transmission.
You may have to manually close the lid switch to watch this process with the lid open.
Mar 30, 2011 | Washing Machines
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
When in wash cycle should the tub move when it is agitating only the agitator moves now
The tub should be locked in place during agitation and does not move.
Eric
Dec 12, 2009 | Refrigerators
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
Washer will not spin
Check your lid switch with a screwdriver pushed into it but, be carefull the switch will now not prevent the tub from spinning
May 29, 2009 | Washing Machines
Switch??
Could be the lid switch . You can bypass it to test it or if you hear the the motor trying to pump out it could be something stuck I the pump.. let me know what you find out..krazytech
Sep 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Admiral AW22 Top Load Washer Logo
435 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
