Question about NetGear WGR614 Wireless Router
No dial tone when I plug into netgear wgr614 - NetGear WGR614 Wireless Router
    Sergeant:
  • 319 Answers
I'm not sure why you think you should be getting dial tone out of a wireless router? If you have bundled service thru your ISP and they are providing phone service then they will provide another device that plugs into your router and connects to your phone jack. This device provides the dial tone.
Posted on Dec 06, 2012
Panth3on
  • 71 Answers
SOURCE: install netgear wgr614
Well which version of that router are you using - there are 9 different version of that model of router - you can find it most likely on the bottom of it on a sticker - find your version and here is a link to getting the manual for your versioin - the manual will tell you how to set it up by using your browser instead of the CD - if you have any problems then i can help you - just let me know. Thanks.
Posted on Sep 03, 2008
  • 58 Answers
SOURCE: my netgear wgr614 is not working. I have no
To establish a wireless connection between the router and computer, the router’s wireless setting (SSID or Network Name, Channel, and Mode of communication) has to be configured. Please follow the steps below to configure the wireless settings on your NETGEAR router.
  1. Connect a computer to the LAN port of the router using an ethernet cable.
  2. Open up a browser and type in the following URL: http://192.168.0.1 or http://192.168.1.1 (depending on the model number of the router)
  3. Type the Username as admin, and Password as password. Then click OK.
    1. To change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
  1. Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
2.
    • Change SSID from default NETGEAR to any desired name (for e.g. Home)
    • Select the Region as applicable - Incorrect selection may cause performance problems.
    • Select any one of the available Channel.
    • Apply the changes
Configuring Wireless Clients:
The steps explained below use the Windows XP wireless client. If your card came with
its own wireless configuration utility, you may use that as well.
  1. Open the Control Panel from the Start Menu.
  1. Right-click Wireless Network Connection and choose Properties.
  1. on the Wireless Networks tab and if unchecked, check the box for Use Windows to configure my wireless network settings.
Then click OK.
  1. Right-click on Wireless Network Connection, Select View Available Wireless Networks
  1. This will lists all the available wireless networks in range. Select your network from the list and click Connect.
If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key (if you are using WEP security, make sure you are typing the network key, not the Passphrase) and click Connect
  1. Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wirelessly.
Posted on May 18, 2009
SOURCE: How to port forward with netgear wgr614
Start>Run>Cmd
Type: ipconfig
a list of numbers should come up. After that, open up your web browser. Look for the number that comes after "Default Gateway"
Enter that into your web browser. It will take you to a page that might ask for a password. Try "admin"
From there you go to basic settings and there should be spots for you to add ports acceptations.
Add them then "apply" or "save" the settings.
After that it will ask you to reboot for the changes to be saved. Do that and you should be good to go man. Make sure you allow the ports through your firewall too.
Good Luck.
Posted on Jul 10, 2009
PC Commando
  • 142 Answers
SOURCE: xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Posted on Sep 19, 2009
leitusdotcom
  • 172 Answers
SOURCE: network Key for netgear wgr614
Hi, taffy_man, the network key is something you configure yourself. If you dont know it you have to RESET the router to the factory defaults.
Take a paper clip, or something sharp, and insert it into the little reset hole in the back of the router, and hold for 15 seconds or so, that'll reset the router. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Or you could type www.routerlogin.com into your internet address bar and it'll ask you for the username and password, the defaults are admin and password..
If that doesnt work do the same thing but first disconnect the power cable. Then while pressing the reset button THEN connect the power cable again but keep the reset button for 10 secons and then go to the routerlogin.com or (192.168.1.1) and do what I wrote above. Then you will have to reconfigure your settings. I hope this helps.
Posted on Apr 29, 2010
Netgear wgr614 v9 not working. no power light. only a buzzing noise when plugged in.
Stop using the device as the buzzing noise is likely going to be a fire hazard. You will be better off recycling the device and purchasing another. It cannot be repaired.
Dec 19, 2010 | NetGear WGR614 Wireless Router
Cannot run smart wiszard to install router
Yes. Plug everything in and turn it all on. Then run the Smartwizard.
Nov 28, 2009 | NetGear WGR614 Router
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
May 11, 2009 | NetGear WGR614 Wireless Router
How to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Jan 05, 2009 | NetGear WGR614 Router
Connection settings for a ps3 via netgear WGR614
you need to check your routers firewall setting by accessing your router through the pc and make sure your plug and play settings are enabled. all can be found on the router setup page. the playstation only requires you to enter the WPSK or WPA wireless encryption key to log on so the problem is usually with the router....hope this helps.
Dec 12, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Networking
netgear kwgr614 i have internet when connecting staight from the cable to the desk top, but when the router is plugged in first there is no connection.
May 20, 2008 | NetGear WGR614 Wireless Router
Netgear WGR614
did you make sure that the cable going from the modem is plugged into the Internet port on the router?
Apr 18, 2008 | NetGear WGR614 Wireless Router
Netgear router WGR614
try using "admin" for the user and "password" for the password. I have this very same router and that was the default settings for me.
Nov 19, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
76 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
