Question about Samsung LN-T4661F 46 in. LCD HDTV
Samsung flatscreen turns on but screen does nothing. HELP please.
I just got this tv from a friend and it did not come with the ID label, so the Model stated above is my best guess. It has HDTV capabilities. I measured the screen and it is 45" 9/10th as any 46" Samsung is. It appears that everything works except for the screen. The screen has no visible cracks. Power up sound and power down sound works when turned on and off. Source button and menu do not change anything on the screen. All indicator lights light up properly. How do I fix it?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Check the internet. Most likely a series of cheap capacitors. Replace them all (the ones that match the culprit). ~.20 each US.
Posted on May 30, 2017
SOURCE: Samsung LTN1765 has blinking green power indicator, but no picture or sound
Try replacing C51, a 10 microfarad 16v. surface mount electrolytic. It's near IC23 on the upper center of the board.
This part had high ESR on a couple of sets I serviced which
kept the power supply from starting.
Posted on May 10, 2008
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
  • 53 Answers
SOURCE: samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
Posted on Mar 20, 2009
  • 10865 Answers
SOURCE: i have a samsung hp
When the power was restored you suffered a power surge. Anything plugged in that did not have a surge protector was at risk. plasma tv's are especially susceptible to this. You will have to take this in to a tv repair shop for an estimate.
If the estimate is over 200 you may want to consider a replacement. Also purchase a surge protector so this doesn't happen again. Regards, Joe
Posted on Feb 23, 2010
  • 6 Answers
SOURCE: Samsung LTP227W
Usually the power supply is bad. Just 3 capacitors 1000uF 35volt rating. The 3 electrolytic caps will be puffed out, simply replace tham and you will be back in business.
Posted on May 22, 2010
Samsung flatscreen tv model LN46C600F3FXZX has sound but no picture
Video section has become compromised and no longer functional. Audio being separate from the Video may work perfectly, but the Video portion sustained damage to the circuit board or the inline safety diode blew. If any parts of the Circuit Board fail, you need to replace the mainboard. The cost to generally fix a circuit board is usually more than the replacement cost for a new unit. Check all fuses or circuit limiters inside the TV and if there are no shorts, burned parts, or obvious smells on the mainboard, transient current may have trickled in and damaged sensitive electronics. Have a professional Technician do tests to locate the source of the problem.
Dec 25, 2013 | Samsung Televison & Video
Samsung TV will not turn on.
OK if it is LCD your and have sounds but no picture you possibly have faulty inverter board that need to be replace
Dec 03, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Hi. I have a Samsung tv that I brought secondhandbut it has no manual to tell me how to change the screen as I only get 3/4 of the picture the right far side is missing I have tried altering the screen...
here are manuals for Samsung LCD TV, you can find the type of your TV on the label from the back side
http://www.usersmanualguide.com/samsung/tv__lcd
Jul 05, 2011 | Samsung Televison & Video
When I started using Netflix, I hooked the Samsung Flatscreen TV up to my Dell Inspiron laptop via a VGA cable and it worked beautifully. Suddenly, the TV indicated that there is no signal. I checked the...
Most laptops have 3 video-display options:
* output only to internal LCD screen
* output only to external VGA port
* output to both LCD and VGA
Hold down the blue 'FN' key on your keyboard, and look at the BLUE labels on/above the 12 'F' keys. One of those Function-keys can be used to "toggle" through the above 3 display modes.
Jun 04, 2011 | Samsung Computers & Internet
Hello, my name is Tom. We have a mitsubishi ws-65613 and of course I have the green blinking light and nothing else happening. Tried to reset, unplug etc. Is it worth messing with or should I just bite...
The tv mitsubishi ws-65613 the DLP tv is big bulky and heavy.Many power issues problems and convergence problems over and over again.Buy a 46" LCD tv Samsung have great apps,friendly and a great picture.The priced is very fair too.
Oct 28, 2010 | Televison & Video
Blurred picture
Is it a tube TV or a flatscreen? If it is a tube then it is possible to correct this, however I'm not sure what caused it. Take the back off the TV, and look for the flyback transformer. It is the unit with a red wire coming out of it, going to what looks like a suction cup on the tube. On the unit there should be a small knob labeled focus. Try adjusting this. If it is a flatscreen, sorry, I can't help.
Apr 14, 2010 | Sharp 27SC260 27" TV
Can I turn on the samsung flatscreen without a remote? The remote got water in it and will not work. Does the tv have a power button located on the tv?
Yes, channel buttons, sound buttons and power button is located at the side of the screen. Look for it. For most TV's its located behind and for some at the side and for some in the front bottom.
Nov 24, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Samsung PCL545R Color adjustment!
i'd recommend you return it to your friend..sounds like quite an issue with the innards.
Apr 20, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung LN-T4661F 46 in. LCD HDTV Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
