Question about Bissell Vacuums
Bissell Proheat 9200-H, won't pick up water to bottom tank, except by hand tools.
  • Bissell Master
  • 18,408 Answers
This could be the problem
Posted on Dec 04, 2012
5 Suggested Answers
SOURCE: my bissell proheat 12 amp will not spray water on
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Posted on Feb 24, 2009
  • 33 Answers
SOURCE: Bissell Proheat 2x 9200
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Posted on Jan 25, 2010
  • 33 Answers
SOURCE: I have bissell proheat 2x 9200 no water or
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: My Bissell ProHeat 2x model
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
zcgb
Posted on Sep 30, 2010
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My bissell proheat pet won't spray through the bottom. the tools work but not the floor cleaning part.
This worked for ours it had alot of little crystallized pieces in the valve cleaned it not water will come out bottom. Thanks!
Oct 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have a model 9200 that is not dispensing fluid,
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have bissell proheat 2x 9200 no water or cleaning solution is dispensing from bottom of machine hand dispenser is not working too. how can I troubleshoot it?
Jan 21, 2010 | Bissell 9200 Upright Vacuum
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Sep 04, 2008 | Bissell 9200 Upright Vacuum
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Jul 24, 2008 | Bissell 9200 Upright Vacuum
Bissell 2X Proheat 9200 - uses lots of cleaner.
May be that the cap and valves on the bottom of the tank is not shutting like it should and letting too much to come out. You may have to replace them.
Mar 10, 2008 | Vacuums
Vacuums Logo
337 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
