I have a Kenmore refriderater I bought in January 2011. The "latch" on the top of the inside ofthe door has broken off. Your help line quotes a $65.00 service fee for a repaire man to come out to th
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
MNTECH
  • 1543 Answers
SOURCE: GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Posted on Mar 08, 2009
  • 1294 Answers
SOURCE: Broken door latch
Why do you want to fish it out, the door might malfunction. I suggest you change the door lock mechansim, can do it your self.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Mar 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE4T Door Latch Replacement Instructions
Okay, here ya go. This link should give you the step-by-step instructions you need:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
I hope this helps you resolve the problem you may have. If you have questions along the way, or require further assistance please let me know.
As far as begin able to determine a visible flaw with the latch, the only part that you can check (that I know of) is the latching mechanism inside the slot in the door. The rest of the latch assembly is a sealed component, like an electronic module. There are a few connectors attached to it that you can check to see if they are making proper contact. You can access the rear of the latch by removing the to panel of the washer. Take the panel off by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then off. You should be able to see the connector by looking down behind the front panel on the right hand side. You can also use this as an alternate method of replacing the latch if you like.
Let me know if you have further questions.
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: DE door switch problem
I bought a switch in Portugal by €7,5 and ...nothing. I bought a drain pump €18 and still not working. I have consult one tecnical expert by phone were i bought the pices and he said tha could be the pwc board (€75). Here in Portugal they quote €25 to come and €30 per first hour...I decided and I bought a new Lg with direct drive but I stored the old Lg (6 years old, without problems, and working 2 times per week)...if you try... and it works tell me ok ? Good Luck.
Posted on Jan 06, 2010
vostendorp
  • 347 Answers
SOURCE: Kenmore washer HE3 broken door latch. How do you
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Posted on Dec 29, 2010
How to open 1998 Lincoln Navigator it latch is broken?
Help:Navigator hood won't open - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Expedition & Navigator
Jan 30, 2012 - I have a 1998 Lincoln Navigator with a battery that needs to be jumped and I cannot .... I've accessed many broken hood latch cables that way. Rear liftgate and glass latch cables -1998 Expedition
Jun 1, 2012
Expedition hatch door doesn't open
Jun 20, 2011
need help replacing door lock actuator....98 Navigator
Jan 28, 2008
More results from www.ford-trucks.com
Sep 28, 2015 | 1998 Lincoln Navigator
How to drivers door latch on 2011 Focus
Sounds like the clip that holds the rod to the latch has come apart or broken ..remove panel and inspect it
Sep 10, 2014 | 2011 Ford Focus
Why won't the door latch?
Make sure the door is not hitting the sides of your cabinet. Also make sure it is not hitting the screws that hold the mounting tabs (located at the top of your dishwasher) to your counter-top. If that's okay, try removing the racks and see if the door will close then. If still no, then you might have a broken latch or bent or broken hinges.
Jul 05, 2014 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
The door pops open after about 10 seconds. We have replaced the sensor that is located on the upper left inside of the door, to no avail. Any ideas? Also, I am not sure if this is the model #..
either the hinges have gotten bent from too much weight being put onto the door when it was open or your door latch might be broken, see if the white plastic door closer on the top inside of the door catches onto the gold colored latch that is at the top part of the dryer door opening, if either one of these are damaged you would replace both as they come as a kit. here is a parts listing:
http://www.repairclinic.com/Kenmore-Dryer-Latch-Parts?z=100
Nov 25, 2010 | Kenmore 600 6965 Electric Dryer
Kenmore HE2T front loading automatic washer...model 110.4756,4757..displaying F22 error message? What does that mean and how do I fix it?
"F22" is a door latch error. It can mean any of the following:
1. The door latch mechanism is broken. Inspect the door latch to ensure it is intact and not broken. Verify the electrical connections are making good contact.
2. The door latch hook (located on the door) is broken or worn. If the latch hook is damaged, it may not allow the door latch to engage and lock properly.
3. The interconnecting wiring between the Central Control Unit (CCU) and the door latch are loose, broken, or not making good contact. The CCU is the main computer for the washer. You will need to remove the top panel of the washer in order to access. Simply remove the retaining screws located in the back of the washer and the panel will slide back, then lift off.
4. Defective CCU. The CCU controls nearly all the functions of the washer, including the door latch. If the CCU fails, the proper lock/unlock signals do not get sent to the latch mechanism.
Determing how to troubleshoot the CCU and Door Latch is in the technical data sheet included with your washer. The tech sheet is located behind the lower toe panel directly below the door. If the tech sheet isn't behind the toe panel, it will be affixed to one of the interior cabinet walls. I do not have the procedure memorized, but there are some tests you can try to determine if the problem is the CCU or latch.
If you determine the latch needs replaced, the following link may assist you:
The procedures I provided are for Kenmore Elite series front loaders, which are the larger cousing to the HE2. The steps are nearly the same except for how to remove the door gasket from the front facing of the washer. The HE2 models are glued on instead of using a wire hoop (unless yours is a later model and has been modified). You can use a metal putty knife to carefully peel the gasket loose and reseal it when completed. A good appliance gasket cement (found at any appliance parts retailer) will work. You can also use a plumber's sealant. Just make sure you use a pliable rubber cement. Do not use super glue.
Some prefer to try to work through the top of the washer and avoid removing the gasket. This may be possible with the larger top loaders, but the smaller models are usually a bit more difficult to access.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
The latch on kenmore micro #721-62622200 is broken at bottom
In order to have the correct operation of the door latch mechanism and latch switches.
  1. Ensure correct adjustment of the Door and the Latch switches.
  2. Wipe off any dirt or grease around the door key where it touches the latch switched and door hooks with a soft cloth. Maintaining the smooth movement of the latch mechanism and switches etc�
  3. After replacement of the latch mechanism and/or Latch switches. Make sure to confirm a smooth operation of these parts are in order.
to view the exact diagram of how to do this manually just click the link http://www.applianceaid.com/micro8.html
Mar 07, 2009 | Kenmore 62622 Microwave Oven
4292x blinking cycle light
Click on Kenmore (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Try pushing the "end of cycle" button.
Dec 30, 2007 | Kenmore 4292x Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
