Question about Indesit W 123 Front Load Washer
Indesit wdg1295w washer/dryer not drying
I was left an indesit wdg1295w washer/condenser dryer in the flat. The washing and spin cycles seem to be ok, but when I use the dryer the clothes heat up but don't dry.
Coldcut
  • 1554 Answers
SOURCE: wil133 indesit 1300 washer dryer
look for debris in the filter,
remove the bottom front panel ( 3 screws on bottom)
Unplug washer ,
open the large access filter screw on in center , be ready for excess water to spill on floor, clean filter and be sure the pump impellers spin freely.
Posted on Feb 25, 2008
  • 1294 Answers
SOURCE: indesit washeing machine
Karen, that was nice.........
Posted on May 31, 2008
grandadfixer
  • 99 Answers
SOURCE: indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Posted on Oct 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Posted on Dec 02, 2008
SOURCE: my indesit widl126s
i cant get the dryer to work i have followed all the instructions
Posted on Mar 18, 2009
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Jan 26, 2011 | Indesit Dryers
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Dec 02, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Oct 11, 2008 | Indesit W 123 Front Load Washer
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Indesit W 123 Front Load Washer Logo
214 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
