Maytag performa model#2300AWW, the agitator came off and I don't know how to put it back on, there is 1 bolt that came off also.
The agitator came off along with the bolt. I tried to put it back on but can't seem to get the agitator to go back on so I canbolt it back down.
  • Sally Maj Dec 05, 2012
    I DID FIND OUT THAT WHEN I HAD SOMEONE FIX THE RIDGES INSIDE THE AGITATOR SINCE THEY SEEMED TO BE JAGGED, THE AGITATOR SLIPPED BACK ON EASILY AND BOLTED IT BACK DOWN AND IT WORKS FINE NOW.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number?
Posted on Dec 03, 2012
  • Sally Maj Dec 04, 2012
    Model# is PAV2300AWW
5 Suggested Answers
SOURCE: Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Posted on Jan 17, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
Lost the bolt to the agitator. washer machine is maytag performa
you just have to order a new bolt. the parts store will need your model number in order to get you a new bolt.
Oct 31, 2009 | Washing Machines
Could you please tell me how to remove the agitator for cleaning on a Maytag top loading performa machine heavy duty.super size 3 speeds quiet series 100 13 cycles Thank you Bob Clark bobgc@bigpond.com
The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
How do you remove the agitator if something is caught underneath.
On a Maytag the agitator either has a bolt under the center cap, or a set screw along the side about 3/4 of the way down. Maytag Alantis and Performa models have a removable agitator cap with a bolt underneath, while the Dependable Care series have a set screw. In either case, you loosen the nut or screw, and the entire assembly will lift straight up. Sometimes they stick and require a little effort to remove. I hope this helps you.
Sep 04, 2008 | Maytag Washing Machines
Seal leaking from tub. How do I remove agitator?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
Aug 11, 2008 | Maytag Washing Machines
How do you remove the agitator on a Maytag Dependable Care Washer?
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
MAYTAG AGITATOR LOOSE
replace the agitator,if you look for a store that sells used machines you'll get the best price. Buy a used one!
May 26, 2008 | Maytag Performa PAV2200
Top of agitator comes off while washing
This agitator has a bolt that locks it to the transmission Pull the softener area off the machines agitator off and look inside to see if the bolt is there.I'll help you any time a problem arrises
Feb 17, 2008 | Maytag Performa PAV2200
Maytag Preforma washing machine
I would suggest Service Technician is cheaper than doing it yourself Bev007. It will save you headache too. Depending on the severity of the damage, you'll be working on the transmission attaching the shaft of the pulsator or agitator.
Dec 21, 2007 | Maytag Performa PAV3200
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
