Question about Maytag Performa PAV2200
Maytag Dryer Model #HYG3657AWW will not heat up
Already changed the "Glow Stick" on the dryer but it still will not heat up when its turned on.
Maytag Model # HYG3657AWW
    Genius:
  • 2,920 Answers
Replace the limit switches they tell it when to get hot and how hot to get
Posted on Jan 11, 2009
MAytag 2300 aww does not heat
If this is a gas dryer it may be the ignitor has failed. There should be a panel you can remove to inspect the burner compartment. Turn on the dryer and look for an orange glow if you don't see any glow the ignitor is probably faulty and should be replaced. If it is an electric dryer it may be a bad heating element. Hope this helps.
Jan 03, 2014 | Maytag Dryers
Gas dryer not heating
The problem primarily is with the solenoid coils mounted on the gas assembly. Real easy fix. I have photos HERE
Bonus: HERE
Feb 05, 2010 | Maytag Dryers
Gas dryer turns on but won't heat up?
There is a little cap on the front of the dryer you can pop off and look in to see if the glow bar is glowing when the dryer calls for heat. If the glow bar does not glow chances are it needs replacing. If the glow bar is glowing it could be a number of things.
It could be one of the coils on the top of the burner is burnt out. It could be the glow bar sensor is not working. (a black box with two wires comming from it located on top of the burner funnel). It could be a thermostat not working.
The first thing to check and this has happened before. Make sure the temperature switch is set for heat and not air dry.
Dec 28, 2009 | Maytag Dryers
How to turn on pilot light maytag neptune dryer
Thing is the dryer does not have a"pilot" it has an electric ignition system with and electric igniter. Go here for more: Dryer Repair Help
Go to RepairClinic.com and enter your model number into the Search box at the top of our website to see all the parts available for the unit.
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have an Amana Gas Dryer Model # ALG643raw
Sounds like the flame detector sensor may have failed, but you really need a multimeter to test the components in the circuit to make sure you replace the right partt
Aug 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer turns on. no heat and timer does not advance?
sounds like glow bar or photo sensor not working properly. should be access panel to veiw ignition system, if glow bar turns white hot when dryer is started, try to clean face of photo senser and re-start. unplug dryer before cleaning sensor. timer will not start until dryer comes up to temp.
May 15, 2009 | Maytag SDG4606A Gas Dryer
Maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Apr 17, 2009 | Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Gas Dryer not heating
Check the thermal fuse on the heat vent canister.
Check the glow bar ignitor on the gas valve.
Mar 03, 2009 | Maytag Dryers
No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Dec 19, 2008 | Dryers
Washing Machines Logo
468 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
