Question about Sony VAIO VGN-FE590 Notebook
Sony Vaio vgn-fe590p, when starting up the screen lights up, but it is dim and blurry. Could this be the inverter, or the lcd screen is bad?
  • Chris Estanislau Dec 04, 2012
    TKs for your reply. No the laptop has not be dropped. When you start up the screen is very blurry. It does not flicker. I have it connected to an external monitor, and everything works fine. I just want to figure out if it could be the invertor or the lcd. If it were the invertor, would i still get an image on the screen?
  • max carson
    max carson Dec 04, 2012
    It's difficult to say for sure. Take a look at this vid:http://www.youtube.com/watch?v=2Yi6GNFcP...
  • Sony Master
  • 7,627 Answers
Start with drivers,http://esupport.sony.com/US/p/model-home.pl?mdl=VGNFE590P&template_id=1&region_id=1&tab=download#/downloadTab . Has it been damaged? Dropped, jarred, etc. It may be the monitor/graphics is going. Hard to say exactly. Is it overheating?
Posted on Dec 03, 2012
hvpatel
  • 152 Answers
SOURCE: Dim LCD display
ccfl tube goes down or inverter cirucuit is fail
need to replace it
Posted on Feb 02, 2009
Geekman
  • 32281 Answers
SOURCE: my sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 24, 2009
  • 476 Answers
SOURCE: Sony Vaio Laptop VGN-CR240E LCD screen flickering
Hi - I have replaced lots of LCD screens,it can be done
HOW TO REMOVE LCD PANEL OF MY ACER LAPTOP.
First ===>>> Remove all power and battery
Each machine is different in construction and size,
but they operate in the same fashion,motherboard,power inverter,lcd panel and cable connecting them together,also there may be a wireless aerial and or camera as well inside the lids frame housing the lcd screen so be careful while dismantling the front frame,it should be a good tight fit,
the lid has a base and a front panel covering the workings of the screen and wiring in a compact frame,remove the screws from the front panel and lift the front frame free from the base,remove the power panel by the screen next to the keyboard this should expose the motherboard insides,then unplug the inverter from the screen,unscrew the screws holding the the frame and carefully lie the screen on a flat surface to unplug the data cable from the rear of the screen, top of the screen rear contains IC chips required to make the pictures,
DO NOT TOUCH THESE >>> STATIC KILLS
It dosent mater if the screen is already dead just remember this when you fit the new screen
Hope this helps,Misterdj
Posted on Aug 10, 2009
Geekman
  • 32281 Answers
SOURCE: Recovery DVD for Sony Vaio VGN-N130G
Contact Sony WEB site support, they can supply a recovery CD.
Posted on Sep 14, 2009
  • 1087 Answers
SOURCE: How to Remove the bezel from a sony vaio
http://www.fonerbooks.com/laptop_8.htm
Posted on Mar 29, 2010
The display system of the vaio notebook went dim then finally died out.what is the possible problem and solution to the same
Hi akeyow..
Sounds like you have either a bad lcd screen or a bad lcd inverter.
To check to see if the screen is bad, connect the notebook to an external monitor that you know is working...if it works the you will have to replace the lcd screen.
If it doesn't work then the internal lcd inverter, will need replacement.
Both replacements take a better than average skill to replace, maybe best left to the pros...or sometimes you can check out YouTube and some people show you how to do it.
Please take time to rate me
Sony lcd replacement:
http://www.screentekinc.com/Sony_Vaio_VGN-CS_Series_VGN-CS215J~W--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is a link to the YouTube webpage for replacement, could not find your model, but I am sure you could use some of the info to replace what you have...
http://www.youtube.com/results?search_query=Sony+VAIO+VGN-CS215J%2FW+screen+replacement&aq=f
Lcd replacement, lcd inverter replacement
Aug 22, 2011 | Sony VAIO VGN-CS215J/W Notebook
Sony VAIO VGN-FE590P screen backlight cuts off but the vga side works is this the inverter
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 22, 2011 | Sony VAIO VGN-FE590P Series (4400 mAh)
My Sony Vaio VGN-NR498E laptop with Windows Vista recently had some issues. The light in the screen seems to have went out. If you hold a lamp up to the screen you can make out the background of the screen...
A dim laptop lcd screen is either the result of 1) a faulty inverter which is a separate piece from the lcd screen or 2) a burned out backlight which is part of the lcd screen. In the majority of instances, the inverter is the cause of the problem and not the backlight as most people tend to assume and therefore does not require the purchase of a lcd screen.
I have done some research and it seems you can fetch a new inverter for around $59.00
Nov 08, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Replaced screen still black but you can see something in the backround
Then you have a faulty Power Inverter.. You need to replace the power inverter below the screen... it is the Long rectangular Circuit board - it is what the lcd wires/plug plugs into.. it converts the DC power going through your laptop back to AC Power to Be able to power the bulb..They average $12 to $30 on Ebay for replacement... just unplug from both ends ( display cable plug and lcd bulb plug ) When Searching on Ebay... type : sony vaio vgn-tx power inverter
Oct 06, 2010 | Sony VAIO VGN-TXN15P/B Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
The screen fades out sometimes and i have to wiggle it to get it back. i have a sony vaio vgn-cr115e
www.ladparts.net
Oct 19, 2009 | Sony VAIO VGN-CR115E/P Laptop
My lcd display is blurry, i plugged it into a monitor and its still working, the lcd sometimes works fine sometimes not
This means that the inverter in your laptop's screen is likely oxidized or starting to go bad.
This is a repairable problem for qualified individuals. It is not a repair for the average user due to soldering and other advanced troubleshooting techniques.
My professional opinion is to go to the manufacturer or a local computer service center to get it fixed properly the first time.
Aug 18, 2009 | Sony VAIO VGN-NR385E Laptop
My sony vaio vgn-n365e screen is Dim
Check out
www.lcdparts.net
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Sony Vaio Display problem
Since the Sony Vaio VGN-CR220E works except that the display is dark, then it would be safe to assume that it is only the LCD display part that is the issue. Often LCD display (of laptops) are working but only that you can not see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen s what you have done. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Sony Vaio VGN-CR220E .
Of course another possibility is that there is just a loose connection or a cold solder in the LCD panel display's circuit boards.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Sony VGN-CR220E/L Notebook
Sony VAIO VGN-FE590 Notebook Logo
60 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
